Question about Necchi Sewing Machines
Reassembling bobbin case on Necchi sewing machine. After I get it in my needle is hitting the bobbin.
Posted by Connie J Alvarez on
R.A. Ellis
  • Necchi Master
  • 12,731 Answers
Install a brand new needle and make sure it is installed correctly. If it still hits the bobbin case, the machine has probably been knocked out of time. Search for "sewing machine timing" or take it for service.
Posted on Apr 29, 2018
5 Related Answers
radcal
  • 196 Answers
SOURCE: Needle & Bobbin out of sync
This description sounds like the machine is out of time. The needle should match up with a cut out section in the bottom of the bobbin area. If it is hitting, the timing has slipped, probably from sewing on a fabric that was too heavy for the machine.
Posted on Nov 14, 2007
Anonymous
SOURCE: bobbin case case keeps jamming
I am having somewhat the same problem with the exception that my needle did not break. I've cleaned and oil, but the bobbin case and projection positioned spring is not communicating to allow sewing to continue. The thread keeps jamming and the bobbin raises up the plate. So, what else am I to do?
Posted on Aug 07, 2008
Anonymous
  • 20 Answers
SOURCE: needle hitting bobbin case model 750
This is a timing problem the hook timing needs adjustment, and possible the needle timing also
Posted on Oct 13, 2009
miket756
Michael Thorpe
  • 2702 Answers
SOURCE: NEEDLE WON'T PICK UP BOBBIN THREAD
im not!
it needs a good service the timeing has sliped out a little, nothing more that that,,,see its not a lost cause just yet
Posted on Oct 24, 2009
Testimonial: "Thanks! I was hoping to avoid paying for a fix, but it looks like I have to **** it up. So much for being thrifty and restyling my clothes."
redcapn
  • 36 Answers
SOURCE: needle hits bobbin case...
If the needle hits the bobbin case the are only 2 things that could be wrong. Lets hope its the easy one, there are more than one length of needles, if the needle is to long or it is not all the way up in the neelde bar, the needle will hit the inside of the bobbin case. Now if that is not the problem then the machine is out of time. ALWAYS check the easy stuff FIRST.
Posted on May 23, 2010
Necchi sewing maching adjustments
try a new needle
rethread the machine top and bobbin
try adjusting the top thread tension
make sure the bobbin is inserted into the bobbin case correctly
Mar 23, 2015 | Necchi Sewing Machines
Help! I'm having problems with my Necchi Lydia 3. Firstly when threading up, the threaded needle refuses to draw up the bobbin thread. I've followed the instructions and the needle comes in and out but...
try a different bobbin
make sure the bobbin in turned the right way in the bobbin case
also the machine may have a timing problem, and having it checked to would be a good idea.
Sep 07, 2013 | Necchi 4575 Mechanical Sewing Machine
I have a necchi sewing machine. How and where do you insert the bobbin in model 525fa
if you have a snap in sewing table remove it first
at the bottom in front of the needle plate area is a bobbin case door
when you open it there is the bobbin case & also should be the feed dogs
always keep the bobbin area clean of lint or loose threads
take note of how the bobbin case is inserted in the bobbin area,, see where the thread tail is at on the bobbin case
then make sure the bobbin is wound correctly or it can cause sewing problems
reinsert the bobbin into the bobbin case the same way it's removed
I also have a necchi sewing machine, the base of your is like the base of mine, if you need a picture of inserting the bobbin,, send me a comment with your email address & I will send you a picture of the threading the bobbin case & inserting it
Nov 17, 2010 | Necchi 3101 Mechanical Sewing Machine
I have a Necchi 537FA sewing machine. It sill sew about 39 stitches and then the thread gets caught in the bobbin area and stope sewing. I've cleaned, changed bobbins, spent time trying to fix the...
have you checked to see if the needle is bent-lay the needle on a flat surface & roll the needle over,, if the needle does not roll good -replace
blunt needle-if the needle makes a popping sound when the needle penetrates the fabric,,the needle is blunt-replace
sometimes if the thread comes off the thread take-up lever it can jam the thread in the bobbin area
try rethreading the machine
check to make sure the thread isn't wrapping around the spool pin
check the spool of thread to see if the notch on the spool is catching the top thread
check to see if there's a burr on the bobbin case
I hope one of these suggestions helps you
please rate this using the thumbs in upper right hand corner
Aug 12, 2010 | Necchi 3537 Mechanical Sewing Machine
Bobbin thread will not pick up
Ensure the bobbin thread is mounted on correctly and using your right hand turn the gear that makes the needle go up and down until it catches the thread.
Apr 08, 2010 | Necchi 3102 Mechanical Sewing Machine
Neddle problem
Sounds like the needle is hitting the bobbin casing. Take it out and re-seat it. Check your manual.
Aug 11, 2009 | Necchi 3537 Mechanical Sewing Machine
How to thread necchi 537L sewing machine
From the reel pin take the thread to the left and over the top thread guide above the takeup lever, make sure the takeup lever is up and and make sure the presser foot is up, take the thread straight down and round the right hand side of the tension unit and back up the left hand side to the takeup lever, thread the takeup lever right to left and take the thread down any guides to the needle, if the bobbin case goes in the front thread the needle front to back, if the bobbin case goes in the side thread the needle left to right.
Jun 09, 2009 | Necchi 3101 Mechanical Sewing Machine
Necchi 534FB
I solved this problem for a friend,!. the needle was in the wrong way and
2 the bobbin case was not properly seated be sure you hear the 'click 'when
reinserting the bobbin case...hope this is helpful Velz
May 01, 2008 | Necchi 3101 Mechanical Sewing Machine
Needle touches a metal part and makes a weird noise!
you could have your needle in backwards-- thats been the problem when mine did that
Mar 14, 2008 | Necchi 3102 Mechanical Sewing Machine
Sewing Machines Logo
196 people viewed this question
Top Necchi Sewing Machines Experts
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
