SOURCE: haier dishwasher
I useto have same problem. For some reason there was water under machine, then i tilted machine, clean water and problem solved. This is built-in dishwasher that is why water acumulates under machine and "leak cut off switch" turn off machine. You can't reset machine while you have water under, machine telling you there is a problem, but Haier wan't put solution on their site - Haier suport is very bad. Sorry for English and hope this help.
SOURCE: GE profile PDW9880J00SS dishwasher just beeps
appears control is going bad,or problem with control circut
SOURCE: Miele Diamante G 2150 SCU
Hi
Plugged system or a jammed drain pump can cause these issues, also make sure the drain hose is not blocked. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller. Hope this helps... Please post back for any further assistance.
Daniel
SOURCE: I have a ge profile
http://www.geappliances.com/search/fast/infobase/10000380.htm
According to this link, it should reset after the power is shut off for awhile. Maybe try holding the start/reset button too. Also check the circuit breaker or any fuses
SOURCE: kitchenaid dishwasher KUDS01DJ Rinse only light
Ok, Turn breaker off at breaker panel. Just off then on. The rinse only light should be on.....not flashing. Now press the start button first and hold; then press the cancel button. That should cancel all lights. Then press wash button then start. If the light is still flashing after you turn off breaker....you might have a bigger problem. May need new control panel.
