Question about Shure Audio Players & Recorders
I'm trying to get the Shure PG58 Microphone and the Shure PG4 Wireless Receiver to produce Audio. After the channels are locked in the audio light does not go on and doesn't produce audio.
Posted by Darren Duarte on
2 Related Answers
Rick
  • 611 Answers
SOURCE: wireless microphone receiver ready light or audio indicator nogo
It is definitely a Sync issue.
1) Make certain the microphone is ON and the light on it is green.
2) Remove the battery cover from the microphone.
3) point the **** end of the microphone (where it says Sync) toward the Sync button the receiver (about 6-8 inches away).
4) Press the Sync button on the receiver. You should notice the light on the microphone flash.
If this still does not work, call Shure Applications at 847-600-8440.
Posted on Nov 18, 2009
Rick
  • 611 Answers
SOURCE: New Shure PG4. RF and audio fm mic OK to PG4 but
Sounds like a complicated issue. Many things could cause this symptom. Try calling Shure at 800-516-525 to see if they can help troubleshoot.
Posted on May 04, 2011
How to sync shire pg4 and pg58
First, make certain they are on the same frequency band. Then, simply set them to the same channel. That's it. It's that simple.
Shure pg4/pg58 wireless handheld mic system goes
It's nearly impossible to troubleshoot dropouts in a forum. Shure has some great troubleshooting hints at: www.shure.com/faq. Beyond that, call Shure at 800-516-2525 and they can help you troubleshoot over the phone.
Sync shure pg58 mic to shure pg4 receiver
Since there are no details provided, call Shure (800-516-2525) for assistance in troubleshooting. Have the mic nearby when you call.
Mic
The PG4 is a receiver. So it should never be transmitting.
New Shure PG4. RF and audio fm mic OK to PG4 but can't get mic to work with Peavy 680E. Tried different inputs, cables. Other wireless unts works OK. Wonder if pinout is wrong. Using balanced in/out.
We are using a Shure PG58 wireless mic. It worked very well for about 1 year and then it would work on/off. Even when we put new batteries in the mic it still just goes dead. Any suggestions?
Unfortunately, there are many, many things that can cause a unit to be non-functional. Try calling Shure to get it repaired, or call Delta Audio at 773-764-3634. Delta Audio also repairs older Shure equipment.
2answers
Where can I by replacement parts for my shure wireless handheld transmitter pg58
If you have a T2 transmitter, there is a place in Chicago that repairs them. Try contact them. Delta Audio, 773-764-3634.
PG24/PG58 Professional Microphone: I HAVE THE PG24/PG58 SET-UP. MY PROBLEM IS THAT WH...
you can check the connection of the microphone to the mixer and other audio appliances connected because the microphone is of high senstivity .
Also do check your power socket where you connect the receiver of the microphone because if the socket is having a partial contact the receiver will goes off and take some minutes to come on.
if this has been check and the problem still persist then you require a skilled personnel to work on it or you take it to the manufacturer...
2helpful
2answers
Wireless microphone receiver ready light or audio indicator nogo
Top Shure Audio Players & Recorders Experts
ADMIN Andrew
ADMIN Andrew
Are you a Shure Audio Player and Recorder Expert? Answer questions, earn points and help others
