SOURCE: Use Zenith XBV443 DVD Player / VCR Combo without remote control
if you need a remote control for your unit go to www.partstore.com and purchase a originald remote for your unit.good luck.
SOURCE: DVD VCR combo has no power
I found out what the issue was with my Samsung DVD-V5500. It was the rectifier diode on the 15V tap of the high frequency transformer. This is the same issue that someone else with a later model V5600 had talked about. The diode had shorted and behaved like a piece of wire.
Seems to be a bit of weak point in the power supply. The issue can be diagnosed by using a multimeter to measure the resistance between the diode cathode and ground. If the meter is measuring 1 Ohm between the cathode and ground, your diode needs replacing. I just replaced it with a UF4003 diode from Jaycar, which is basically an Ultra Fast 200V 1A diode suitable for switching the high frequency (20-30kHz) output from the transformer.
The diode is located at the rear right hand corner of the board on the output of the power supply section. A picture below shows the new diode between orientated east-west between the large capacitors. The original diode that failed was an SHG2D SHS.
SOURCE: Zenith XBV443 DVD Player / VCR Combo - Set Clock Manualy
I have the Zenith xbv613 model DVD/VCR player and also need to change the clock set up. For the xbv613 I had to switch the player to VCR. The menu button did not bring the clock set up in DVD. When I switched to VCR and hit the menu button the clock set up showed, where I used to right arrow button to change the time. Hope this helps.
SOURCE: DVD PLAYER Locker
press the stop key on the television and the on/off button on the remote at the same time.
