My Whirlpool WDT730PAHW does things like stopping for a while, takes in too little water and skips parts of the cycle when on the sensor cycle. I have asked elsewhere and think I may have narrowed it down. Could it simply be the turibidity sensor that is messed up. If it is, how hard is it to replace on this machine?
SOURCE: Washing Machine is not draining in rinse cycle to go to spin cycl
you both seem to have bad lid switches. A bad lid switch will prevent draining and spinning.
SOURCE: Washer fills slow only in the rinse cycle
The first thing I would do is remove the hoses from the inlet valve and make sure the screens are not clogged in the valve. On some models the valve will compensate on fill opening both hot and cold. It will not do this on cold rinse. Before ordering any controls check this out first. If it's still the same I tend to believe it's a valve problem. The buzzing you are hearing is the valve. Catriver, post back.
I believe the selector knob on a Whirpool just has to be turned counter-clockwise with the selector pushed in. It will spin off the shaft and then the outer indicator dial will pull off. The shaft also has a keyed slot that will only allow the dial to be removed and installed one way, so there should be no question as to how it goes back on.
Was there a reason as to why you are removing the washer selector knob? If this is a simple matter of replacing a broken water temperature selector, you shouldn't have to remove any of the control knobs to gain access to the selector. The entire front panel comes off by removing the screws holding it in place. That way you can access the broken selector from behind the front panel much easier. Just remove the panel right above the washer top (under the dryer) and it should expose the front panel mounting screws. Remove these screws and the front panel comes off. Just make sure the unit is unplugged before you begin. I hope this helps you. Let me know if you need further assistance.
SOURCE: washer
The symptoms you describe are typical of a broken lid switch. The lid switch is located under the washer top on the right hand side. It is activated through a slot by a small plastic piece on the lid called a "lid strike". Make sure the lid strike is still installed and not broken. Make sure the lid switch itself is not loose, as well. There are two mounting screws along the washer tub opening that hold it in place. If the screws become loose the switch will not make contact with the lid strike when the lid is closed. If you need to replace the switch or lid strike, the parts are available at searspartsdirect.com. Just type in your model number and look under the "Washer Top and Lid" heading on the next page. The lid switch is listed as item number 22 (part #3355806) and the lid strike is listed as item number 16 (part #358684). Both parts combined will cost you about $30. If you have further questions and/or require additional assistance, please let me know. I hope this helps you.
SOURCE: Whirlpool cabrio .....
I imagine it it has detected suds and is doing mini loads to correct the problem. I have a manual HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
