Question about Photography
SOURCE: nikon n75 problem loading film
I have (had) the same problem. I came onto this site to find out what I can do to fix it. It didn't help. I got pissed and almost threw the camera away. So I decided to get a little rough with the camera, (i normally wouldn't do this but i was going to throw it away).
I loaded the film like normal but before I closed the back I manually wound the film around the opposite spool. I guess I fooled the camera into thinking it had already wound the film.
When I closed the back of the camera everything worked fine.
I then snapped off the pics the camera said were left.
After this first role, I loaded the next role like normal. The camera worked like a charm!
By the way...the mirror dropped back down when I manually wound the film around the spool.
I hope this works...if it doesn't make any sense feel free to email me with any questions..
GOOD LUCK.
andy
amasseur at gmail dot com
Posted on Feb 09, 2008
SOURCE: N75 will not load film
how do you develope the pics after you take them
Posted on May 24, 2008
SOURCE: Film will not load
Took out the battery, then put it back in. The film then loaded properly.
Posted on Jul 23, 2008
SOURCE: Film stuck in camera
First, replace the batteries, turn on the camera and try again. If that dose not work, you need to take the camera into a darkroom, a room that is 100% totally dark. The slightest light leak could fog your film. If you do not have a room in your house that you can make light tight during daylight, try doing this at night, Once you are in the darkroom, you will need to work by feel. Open the camera back and feel for the film magazine. If there is no film protruding, you are ok and can turn on the lights. If not, you need to pop the magazine out and use the protruding knob on the end to manually wind the film into the magazine while you alternately pull the film off the take-up spindle. Once all the film is in the magazine, you can turn on the lights.
Posted on Nov 30, 2008
SOURCE: film advance lever goes back and forth putting no
first make sure the rewind button is not stuck down. open the back door and rotate the advance sprocket back and forth to release the button. if that did not work take the bottom cover off and check the white plastic gear near the take up shaft. if that gear broke it will have to be repaired by a camera repair person.
there are no new parts for this model so get a cost estimate first.
Posted on Dec 18, 2009
