Question about DISH Network Televison & Video
Connecting HDTV and Dish Network cables
We have tried connecting it via HDMI1, HDMI2, and HDMI3 cables, none have worked. It keeps only showing the LD twirling symbol and No Connection. Ugh. Please advise.
Will
    Habit-Forming:
  • 91 Answers
Try connecting it with RCA cables.
Connecting HDTV and Dish Network cables - high-performace-triple-rca-patch-cable-25-135-1-undefined-undefined-0.jpg
Posted on Mar 27, 2020
5 Related Answers
Anonymous
  • 8 Answers
SOURCE: Dell 3000cn Network Connection not working
First of, the ethernet must be 'on'. If dhcp available, set it to auto (or dhcp.. anyways..) and let it reboot, just in case :)
if not, try setting the IP-setting yourself. They should be somewhat similar to the settings on your local computer(s).
To add the printer to your computer, select 'Local' printer and specify 'tcp/ip' as which port its connected to. In the new window the ip to the printer should be entered. :) (at least for XP this is..)
Hope this gave you the correct solution..
Posted on Mar 18, 2008
Anonymous
SOURCE: RCA flat panel L42FHD37 When first
You can easily fix this audio problem by downloading a software upgrade for your HDTV. And you don't have to be a rocket scientist or a brain surgeon either ;)
If you need to find the software upgrade:
Go to RCA.com and click on Support, from there you will click technical support. In technical support, click on the link called Software Download. Scroll to the bottom of the page where you will find 2 links. The first link will tell you how to download the software to a Mini Cruzer USB drive (you need at least 15MB of space) and the second link is the software download itself.
Posted on Dec 10, 2008
Anonymous
  • 151 Answers
SOURCE: Dish Network connection and surround sound
HI, connect audio output from tv to system,you may have to turn this on or turn up in tv menu for some sharp tvs,this should get sound for tv and dvd and anything else you hook up to tv.
Hope this helps.
CABLE GUY.
Posted on Mar 29, 2009
Anonymous
  • 56 Answers
SOURCE: Vizio - when i touch any button on my remote the
Looks link the remote is damaged. If you are still in warranty, You can call the customer care and ask for a replacement.
For assistance, please call 714-668-0588 or email us at [email protected] To purchase or inquire about accessories and installation services for your VIZIO LCD HDTV, please visit our website at www.VIZIO.com or call toll free at 888-VIZIOCE (888-849-4623). We recommend you register your VIZIO VW32L HDTV10A either at our website www.VIZIO.com or fill in your registration card and mail it in. For peace of mind and to protect your investment beyond the standard warranty, VIZIO offers onsite extended warranty service plans. These plans give additional coverage during the standard warranty period. Visit our website or call us to purchase a plan. Write down the serial number located on the back of your VW32L.
VIZIO Remote Control Precautions The remote control should be kept dry and away from heat sources. Avoid humidity. If the TV responds erratically to the remote control or does respond at all, check the batteries. If the batteries are low or exhausted, replace them with fresh batteries. When not using the remote control for a long period of time, remove the batteries. Do not take the batteries apart, heat them, or throw them into a fire. Do not subject the remote control to undue physical stress, such as striking or dropping it. Do not attempt to clean the remote control with a volatile solvent. Wipe it with a clean, damp cloth.
Precautionary Tips for Inserting the Batteries: Only use the specified AA batteries. Do not mix new and old batteries. This may result in cracking or leakage that may pose a fire risk or lead to personal injury. Inserting the batteries incorrectly may also result in cracking or leakage that may pose a fire risk or lead to personal injury. Dispose of the batteries in accordance with local laws and regulations. Keep the batteries away form children and pets.
Posted on Oct 06, 2009
Chi Chu
  • 8457 Answers
SOURCE: I have a sony blue
Tries tv unplug,replug it back like about an hour later.Than tries go into the tv menu do a resetting to factory setting in every settings on the tv.Than reconnect the Blu Ray player again should work.If not the tv and Blu Ray player softwares main firmware just not compatibles.The only solution is just don't used it on this tv,because if u tries to upgrade the tv firmware or the Blu Ray firmware and u get the wrong upgradable version in the tv or Blu Ray player.That it u in deep ****,than the tv or Blu Ray player well not functions at all or have multiple orperational problems during it playing times.
Posted on Jun 18, 2011
Can't keep the HDMI2 setting for watching streaming channels - TV automatically reverts to HDMI1
That's because you have connected another device in HDMI1, the TV detects it as power on, and then change HDMI2 to HDMI1.
Try to power off the device in hdmi1, or you can even try to change HDMI2 to HDMI1 port ;)
Jan 15, 2018 | Televison & Video
My panasonic viera TC-55DX700C has 3 HDMI inputs. But, when I press the input button on my remote control, I can only select HDMI 1 or 2 or a component, not HDMI 3. Why?
Usually when you have more than one HDMI port you always should connect to the 1st and any other component extra to 2 then 3. In your set HDMI1 is best for viewing for 4K or default, HDMI2 is for a stereo that supports ARC and HDMI3 is for extra components. In most TV now the set will not let you connect to an input source unless you physically have a component with a cable in that source port first. I'm figuring that might be the case of your TV set.or else it wants you to use HDMI1 first If you do have a cable in HDMI3 with a component and it's not letting you connect to it, then the other thought could be that the plug has gone bad,
Apr 02, 2017 | Panasonic Televison & Video
What channel do I put my LG TV on to connect my Sony blueray player to watch netflix
channel is not the correct path
you need to be thinking What input source do I need on the tv
atv dtv - THIS IS FOR AN ANTENNA CABLE
hdmi1 hdmi2 hdmi3 av1 av2 these are input sources
look on remote for input or source button .
HDMI 1
Apr 18, 2016 | LG 42LC2D 42 in. LCD HDTV
Is HDMI4 correct or HDMI1?
how many jacks do you have . I would think it will be 1 or 2
Feb 22, 2016 | Dynex Televison & Video
Trying 2 watch dvds on my 32 in funai tv cannot down load user manuel
do you have a hdmi cable connected to the tv?
what are you using for a dvd player?
Feb 05, 2016 | Funai Televison & Video
How do I connect a Toshisba soundbar?
Your sound bar should have some sort of HDMI IN and HDMI OUT. This means that there are at least one place to plug a HDMI cable into the bar from either your dish or bluray player and then you take another HDMI cable and plug it into the port labeled HDMI OUT and this will plug into your TV either in HDMI1, HDMI2, or HDMI3 and then it will provide sound for the device. Unfortunately you didn't not list the item so I can not look it up to see if it can accept multiple devices so if it only has two HDMI ports then it can only support one device and you will have to manually change out devices through the HDMI IN port. Essentially the soundbar is just a pass though and takes the sound and sends the picture to the tv.
Jun 03, 2013 | Sanyo Dp55441 TV
I am trying to connect dish network as a remote Tv (a second tv) on my panosonic P46c2. My old tv connected with a coxial cable into the "antenna cable in". How do I see the picture on this tv?...
You may need to run a channel scan or add the channels manually in your TV menu. If you need assistance please e-mail me at: [email protected]
Daniel Busa
DISH Network
Customer Service
Apr 20, 2011 | Panasonic TCP46S2 TV
I am connecting Yamaha DVD player to the Vizio M420 NV via HDMI. i have a picture but no sound. how do I gain audio when using HDMI?
HDMI has both Audio and Video (High Definition Multimedia Interface) and should carry both. However, I had this problem with a client just the other day and it turned out that the firmware on his TV needed to be up[graded. Different model TV, but I believe you may need to download the latest software/firmware update via your PC and put it on a flash drive and then flash the firmware on your TV to get it to work. Sorry I don't have the specifics; I was stumped and the Time-Warner guy ended up doing it. I hope this at least sends you in the right direction.
James
Apr 17, 2011 | Vizio Televison & Video
Everything connected, the screen shows but the
Try connecting the PS3 to your TV through a different port. For example, if you are using HDMI1 on your PS3, try HDMI2 or HDMI3.
Try a different cable. If you have a friend with a working cable try that.
Try a different output on the PS3. For example, if you are currently using the HDMI port, see if the standard composite or component output will work.
While convenient to plug things into an AV reciever, I find that just adds another link in the chain of devices that could go wrong.
Good luck.
Jul 14, 2010 | Sony Playstation 3 (PS3) Console
Televison & Video Logo
82 people viewed this question
Top DISH Network Televison & Video Experts
matt martin
matt martin
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
