Question about Measuring Tools & Sensors
My Acurite rain gauge quit working. Does the outside unit have a battery?
Posted by Alice Clawson on
  • Anonymous Jun 16, 2019
    Rain gauge not working. Changed batteries...nope. Took the base off. There was a spider web and eggs that were obstructing the float inside. Put it back together. Works fine now! Instructions on how to do it is on the Acurite website.
STEVE SPAM REMOVER
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • 35,822 Answers
Yes it does. lithium batteries are preferred
Posted on Apr 25, 2018
4 Related Answers
Anonymous
SOURCE: Wireless sensor quits working
take it back
Posted on Mar 15, 2008
Anonymous
SOURCE: acurite 1097-rx will not display outside temp or
I had same problem. Take all batteries out of both units. Put the batteries in the remote sensor FIRST. Then put batteries in the main unit. Within five minutes, they will link up. Problem solved!
Posted on May 11, 2010
Anonymous
  • 17 Answers
SOURCE: My AcuRite 00992 wireless weather
Double check the batteries to make sure they are installed correctly. If one of the batteries in the outdoor sending unit is in backwards, it will not send the outdoor data. On the indoor unit, there is typically one battery that is used for receiving the signal from the outdoor unit. If all of the batteries are in correctly but that one, you will see the display and the indoor temperature information, but the outdoor information will not be displayed.
Posted on Oct 21, 2010
Anonymous
SOURCE: acurite 00616 inside outside thermometer.
I just found my manual for the Acu>Rite Wireless Weather Thermometer Model #00616, do you still need directions?
Posted on Nov 16, 2010
My station has quite registering the rainfall amount
This is nearly always due to the batteries not having quite enough power. Oddly enough, it is normally the battery in the head unit, not the satellite unit. Mine are powered by CR2032 button batteries. I buy them 10 at a time in a bulk pack from here.
Battery Buyer Batterybuyer com
Oct 10, 2016 | Klockit AcuRite 02001A1 Weather Station...
Why can't I receive input from the outside sending unit?
Make sure that all the batteries are good!!
This procedure outlines the typical process to pair the sensor and base.
Base Station Battery Installation
·Remove the printed vinyl label from the LCD screen of the base station
·Position the remote sensor near the base station
·Open the battery compartment at the back of the base station and insert (2) AA batteries according to the polarity markings. Replace the battery compartment cover.
·Within a short time the RF signal icon (located to the left of the outdoor temperature channel indicator) will start flashing. This indicates that the base station is ready to pick up the RF outdoor temperature signal from the remote sensor. It will continue to flash for 3 minutes or until the signal from the remote sensor is detected.
Register the Remote Sensor
·Open the battery compartment at the back of the remote sensor and slide the channel selector switch to your desired channel. For the first remote you may select any channel, for additional remotes select any unused channel
·Insert (2) AAA batteries according to the polarity markings. Be sure to install the batteries in the remote within the time that the RF signal icon is flashing on the base station. 1541 WeatherGuide Wireless Weather Forecaster with Barometer
Jan 07, 2016 | Measuring Tools & Sensors
Model 00754W4 does not sense outside temperature..new batteries have been placed correctly in both inside and outside units..noW what do I do?
We would recommend a reset of your unit. Please verify that you are using good-quality, standard alkaline batteries such as Energizer or Rayovac, then follow the steps below.
1. Bring both the sensor and display unit indoors and remove at least one battery from each.
2. Make sure the A-B-C switch on both units match. Sometimes changing to a different channel can help.
3. Reinstall the battery in the outdoor sensor.
4. Reinstall the battery in the display unit.
5. Let the units sit within a couple feet of each other for about 20 minutes to gain a strong connection.
If you need any further assistance, please contact AcuRite Customer Support at 1-877-221-1252 or [email protected]
Dec 03, 2014 | Acu-Rite Acurite Wireless Indooroutdoor...
Need manual for accu-rite 00592TX
My outside gauge went flying off my porch in a gust of wind. I found everything but the back that covers the batteries. Can I get a replacement back?
Dec 05, 2013 | Acu-Rite AcuRite 00592A2 Wireless Humidity...
Why is the outside temperature not displaying on the base?
After a battery replacement, the outside and inside units have to "talk" to each other before you can get a display. Also, the outside unit's batteries have to be replaced first. You should not press any buttons for 10 minutes until the two units have finished "talking"
Jan 24, 2013 | AcuRite Acu-Rite 00593W Wireless Weather...
How to reset my Acurite 1099rx after replacing battery
http://www.acurite.com/advancedsearch/result/?q=1099RX
There is no reset button, installing new batteries causes the sensor to reset itself.
Try removing and re-installing the batteries.
Good luck,
Steve
Jan 15, 2013 | Measuring Tools & Sensors
I have this model and the outdoor temp sensor isnt working, and yes both modules have brand new batteries in them. what should i do to get the outdoor temp sensor to work.
My outside display stopped working, but the inside display still worked. I found that one of the two batteries in the inside unit was almost all the way dead. Once I replaced both batteries the outside display worked. I also checked the batteries in the outside unit. After all batteries were installed, I pushed the small button that is inside the battery compartment on the outdoor unit. It's now working perfect..
Oct 10, 2010 | Acu-Rite Acurite Wireless Weather...
My acu-rite wireless thermometer model #00604RX isn't capturing the wireless sensor signal..both have new batteries and worked before changing old battery..reset the buttons too...help
Double check the batteries and the direction in which they are installed. If there is one backwards in the sending unit that is outside, it will not send a signal. Also, there is typically one battery in the indoor unit that is responsible for receiving the signal from the outdoor unit. If all of the batteries are in correctly except that battery, you will see the display, but will not get the data transmitted from the outside sending unit.
Sep 18, 2010 | Acu-Rite Acurite Wireless Weather...
My AcuRite 00992 wireless weather station has suddenly quite displaying the outside humidity and dew point. Batteries are all new. I have lost my manual to troubleshoot this problem.
Aug 27, 2010 | Acu-Rite Adagio Clock Radio
Measuring Tools & Sensors Logo
2,051 people viewed this question
Top Measuring Tools & Sensors Experts
Marvin
Marvin
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
