Question about Pyramid Office Equipment & Supplies
Pyramid 4000 time clock doesn't take the timecard at all. No errors show up.
Posted by Robin Adams on
I need the instruction manual for the SEIKO pyramid talking clock from 1984.
You might try starting at this page from Seiko
(I could not further because you do not give exact model number)
Instruction booklets
10.June.2015
Jun 10, 2015 | Seiko Gold Tone Pyramid Talking Alarm...
I need to know how to alter the volume on pyramid T-10 talking clock for the blind
Recommend contacting a local car audio professional or Pyramid customer support directly here:
http://www.pyramidcaraudio.com/ContactUs.aspx
Jan 24, 2015 | Pyramid Car Audio & Video
AMANO MJR 8000 print problem
it needs to be serviced. try www.gatewaytime.com
Jan 17, 2014 | Compatible 12 packs - Amano MJR 7000 /...
Amano MJR 8000 cuts off top of numbers on timecards
this is caused most likely by one of two issues:
1. The ribbon guide is misaligned or bent
2. A print needle within the printer is stuck or broken.
Try www.gatewaytime.com they offer affordable time clock service and parts.
How to fix the clock in and out
Print Method: Press the Mode button until P5 (Program Mode 5 for Print Format) is displayed.
Press Setting to choose one of the following Print Methods.
The TC100 has two settings for print activation: Manual or Automatic
1 = Automatic (default setting) - The TC100 automatically prints when the time
card is inserted.
2 = Manual - After inserting the time card, press the Print Button to activate
printing.
Press Select to confirm the Print Method chosen. Press Mode to return to normal operational
mode.
Step 3: The control knob corresponds to Step 4: Insert the time card. The time the
format of the time card. Turn time will automatically print in the
the control knob to select the desired selected row.
day and print row. I hope this help let me know : - )cw7ahhgaaaaasuvork5cyii=
Jan 10, 2012 | The Times ROYAL TC100 TimeMaster Time...
4003-0s clock wont count does turn to show time or swicth on lights
1) If timer dial is not rotating, then the clock motor has gone bad.
New paragon clock motors are not sold anywhere I know about.
http://waterheatertimer.org/Paragon-timers-and-manuals.html#4000
2) If dial rotates on time, but trippers don't work, then buy new X2772 trippers.
3) Buy new 120Volt 4003-00 timer at Southside for $86:
http://www.southsidecontrol.com/acatalog/Products_Paragon_4003_0_24_Hour_Time_Clock_4003_00_3823.html
4) BuildingHVAC sells 4003-00 timer for $56.00
http://www.buildinghvac.com/acatalog/Products_Paragon_4003_0_24_Hour_Time_Clock_4003_00_3709.html
Aug 04, 2011 | Paragon Amf 7008-00 Timer 7 Day 120 Volt...
Oven doesn't work. Panel shows "FFF"
FFF code - Control error, failed EEPROM
The main control operates a series of software commands, which control the various features and functions of the oven. Each function or operation has a numerical value assigned to it. The numerical values can be added up - this is called the check sum operation. Every time the system is powered up and after each clean cycle the system performs a check sum and compares the value to the value programmed into the software (stored in memory).
An EEPROM check sum error or FFF code occurs when the values differ. If this happens, replace the oven control board (also called clock or ERC).
Replace the oven control board (also called clock or ERC).
Hope this helps.
Jun 27, 2011 | Kitchen Ranges
What does Error 1 mean?
Error 1 - Indicates time card stuffing. If an individual tries to force a card into the unit, the 4000/4000HD will accept the card but will not print or store any payroll data. If this situation occurs, an ERROR 1 will show on the front display and the card will not be "punched".
Solution: Rerun the time card through the time recorder without pushing on the card.
Resource 1 : Owner's Manual
Mar 01, 2011 | Pyramid 4000 Self Totaling Employee Time...
Top Pyramid Office Equipment & Supplies Experts
Ekse
Marvin
Marvin
Are you a Pyramid Office Equipment and Supply Expert? Answer questions, earn points and help others
