Question about Dell Tablets & eReaders
My dell tablet has a windows 10 and will not rotate the screen
Posted by Mikeli Ray on
mariyamerry77
    Sergeant:
  • Dell Expert
  • 197 Answers
Customer care support service number +1--833--[272]--0777,,,,,,,call them_______ Android has the auto rotate screen option which automatically rotates your device's screen when you move your device between landscape and portrait mode. This feature is a useful one. But, not for all.
Posted on Dec 04, 2018
Joseph Wright
  • Dell Master
  • 1,729 Answers
Reads like the display drivers need to be updated to some compatible with Windows 10..
Posted on Apr 25, 2018
1 Related Answer
emissionwiz
Marvin
  • 85239 Answers
SOURCE: How to rotate the screen on a Lenovo 10 tablet
https://support.lenovo.com/us/en/solutions/ht101162
Posted on Feb 22, 2017
How to get my tablet to start rotating again. It is set to auto rotate but it won't stop working.
This varies by operating system which is why it is a good idea to post the brand, model, and operating system with a query.
For a Samsung Galaxy 10.1:
Type apps is the upper right corner. Then tap Settings from the all tab. Then in the left menu, tap screen. Then, tap auto rotate
For the Inspiron Dell 2-in-1 with Windows 10:
Go to Control Panel> Display>Change Display Settings and then make sure that the "Allow the screen to auto-rotate" is selected. Or try the following: Place the tablet into Pad/Tablet mode.
Click the Start Start menu and select Settings. Click System.
Click Display. Scroll down and toggle Lock rotation of this display to ON.
Or this might help:
Click the Start Start menu and select Settings. Scroll down and toggle Lock rotation of this display to OFF.
Screen won't rotate
Screen won't rotate at all - Android Forums at AndroidCentral.com
forums.androidcentral.com > ... > Verizon Galaxy S3
Aug 4, 2012 - 25 posts - ‎22 authors
So far this is the absolute best phone I have owned hands down. I have a small but annoying problem of the screen not auto rotating, or rotating ... Samsung Galaxy S6 Screen rotation won't work
Apr 18, 2015
Note 4 problem - Screen won't rotate
Apr 12, 2015
S6 Edge - Screen rotation does not work properly
Apr 10, 2015
Screen won't rotate
Jan 3, 2015
More results from forums.androidcentral.com
1helpful
2answers
How can i fix my dell venue 8 pro? It won't turn on at all.
Seems to be a common problem.
You are on the right track with holding down power button.
1. Hold down for 20 secs, Wait 5secs, hold down for up to 10 secs, it may turn on before then.
2. Does the screen have a dim glow, even though there is nothing on it?
Let it discharge itself so the glow is gone, may take some hours.
Plug it into charge for at least 30 mins.
Try to turn it on.
More info here
http://answers.microsoft.com/en-us/windows/forum/windows8_1-performance/why-wont-my-dell-venue-8-pro-windows-tablet-turn/50573983-8cb7-4770-bf5c-478e63ec5cf8
Is it normal for the Dell Latitude 10 w/windows 8 for the screen to dim and brighten?
If you have power saving settings on and you do not have the a/c plugged in, then yes.
How can you get the touch screen or pen work on the dell latitude xt2? I can't figure out how to get the buttons to work or the screen to rotate.
What OS are you using ? Windows Vista or Windows 7 ?
In order to get the buttons and touchscreen working, you need to install the proper drivers.
Go to http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=LAT_XT2&os=WLH&osl=en&catid=&impid=
Select your operating system
and download the following drivers and install them in the following order :
  1. System Utilities : - > Dell Utility : System Software
  2. ControlPoint -> Dell - Application : ControlPoint System Manager
  3. Input device drivers - > Ntrig Application
Restart your computer. Run Windows Update Restart your computer Everything should work.
Hi. I have a problem with my fujitsu lifebook t4215. When windows is runnning and I change the notebook to tablet config, I cannot get the display/screen automatically rotated. Even when I press the Screen...
Do you have Windows 10? As there may be an issue with screen rotation.
However to check your settings:
  1. Place the tablet into Pad/Tablet mode.
  2. Click the Start menu and select Settings.
  3. Click System.
  4. Click Display.
  5. Scroll down and check the status of Lock rotation of this display .
1helpful
Rotate windows on a toughbook
Is it just that the window is upside down??
1. Try pressing Ctrl + Alt + arrow (left, right, up or down) to rotate the screen.
2.Press the hotkeys and arrow keys until you have the desired rotation. This works with most video drivers on Windows XP. If this doesn't work let us know.
4helpful
Screen rotate
Hello snapshots,
Here is what you do:
1) Click on a blank area of the desktop (not sure why, but sometimes this is necessary). 2) Press the toolbox button on your monitor. It is located in between the rotate screen button and the secondary "Esc" button. A tablet shortcut menu should appear in the middle of your screen. 3) Select "Settings" at the bottom left of the menu. This will open a "Customize Tablet Shortcut Menu Settings" Window. 4) In the "Auto Screen Rotation" portion of the window, make sure the "Enable ActiveRotate" box is checked.  5) If you choose, you may also want to click the "Calibrate" button. This will step you through customizing the ActiveRotate to your personal preference. 6) Click "Apply" and then "Ok".
Please note, that with the internal wi-fi connection enabled, you cannot use the X61 in tablet mode in certain orientations. Nothing bad will happen if you attempt to do this; but you will notice a message popup telling you this, as well as having the screen automatically switch orientations on you. This is normal and has something to do with the wi-fi antenna location.
Hope that helps!
Jeff
Tablets & eReaders Logo
Top Dell Tablets & eReaders Experts
ADMIN Canada
ADMIN Canada
ray gallant
Are you a Dell Tablet and eReader Expert? Answer questions, earn points and help others
