http://www.royalsovereign.com/customer-support/faqs-frequently-asked-questions/portable-air-conditioner-faq.html
Why does my portable air conditioner cool for a short period of time and then turn off?
Have you extended the exhaust hose with another? The unit can ONLY be used with the included exhaust hose (dryer type exhaust hoses will cause the unit to over heat).
How close is the unit to the wall? If the unit is only inches away from the wall and you are running the exhaust hose out a window, more than likely their exhaust hose bend is at 90 degrees which restricts air flow. In order for the unit to run more efficiently and not overheat, it should be at least 1-1/2 feet away from the wall and the exhaust hose should not exceed more then a 45 degree angle.
Are you exhausting the unit out a hole in the wall? If so, are you using a flap vent on the exterior of your home/office? The flap may be too rigid and not open continuously. The compressor is not strong enough to push the air through and therefore will only run for a short period of time before overheating and shutting off. You should take the flap off the vent and replace it with a piece of screening.
Are you venting it into a ceiling or basement? Does the ceiling or basement have ample ventilation? If the ceiling or basement does not have a way of pushing the heat from the exhaust to the outside, the unit will work for a short period of time and then eventually overheat and shut off.
Portable Air Conditioner FAQ Portable Air Conditioner Frequently Asked...
SOURCE: Cool air when running; warm air when compressor is off.
It sounds as if warm outside air is being drawn back into the room when the unit is not actively cooling. Portable units depend on room air to carry the heat outside, & therefore will not work properly if the room is too airtight. Provide a makeup air passage by leaving the door slightly open, & see if this helps. Use a room thermometer to see if your desired temperature is being reached. Note that if the wind is strong & coming from the wrong direction, it may not be possible to prevent warm air drawback.
SOURCE: Front air condition does not blow cold. Rear air condition does
sounds like a damper door in the front not working properly, these are actuated by the front temp control, the door is operated by either a manual cable, and electric actuator, or vacuum. I hope this helps you zero in on your problem. Merry Christmas
SOURCE: Blueway split system wall air conditioning doesn't work properly.
Hi,I have had problems with my Blueway A/C it was very cheap but NASTY,anyway I might be able to help, I made a website with my manual that includes the error codes that I could not find on the net anywhere ,I have also sourced a company in sydney who has spares and have the contact details listed and started a forum that we can help each other out with
SOURCE: (1.7 cu) Chefmate Fridge Doesn't Get Cold
The Chefmate 1.7 fridge uses a thermalelectric device (TED) to provide cold air. There are no moving parts there. The problem is usually in the power supply. That is the PCB on the left side behind the back cover. If the fans are running then your thermostat is bad or the TED is cracked. You can buy these ebay or other places on line. To change one you must carefully remove the large heat sink. The TED itself is only about two inches square. If you decide to replace this unit be sure to get a supply of heat sink glue. Otherwise you will end up with a hot (or cold) spot on the TED possitly causing another crack.
SOURCE: My 2004 Jeep Grand Cherokee's air conditioning
The blend door is getting stuck in the HVAC housing. Common problems for jeep. Replace the HVAC blend door. hope this helps.
