Vacuums Logo
Question about Kenmore Vacuums
Kenmore upright progressive vacuum model 11635922500
I would like instructions and/or a schematic on how to replace the beater bar
Posted by Steven Lasek Sr on
5 Related Answers
Anonymous
SOURCE: Beater Bar Belt Removal from Upright Electrolux Vacuum
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=783793
Generic problem for all Vacuums
Beater bar Belt Removal from Upright Electrolux...
Posted by wrenn on Jul 14, 2008
I am trying to change the belt on an Electrolux Model 1717 Upright Vacuum and I am having difficulty disassembling the vacuum to remove the beater bar and belt.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. . Normally there are screws, clips or levers that would remove the bottom plate or if that does not work then the top cover will come off and that will expose the belt. Once that is off and the belt is exposed then cut off the old belt and then lift up the brushroll on the pulley end and install the new belt around the pulley end and re-install the brushroll. Then use a belt puller or a screwdriver with a bent right or left end to stretch the belt onto the motor pulley and then track the belt in a straight line and reverse you steps in the reinstall of the top cover or bottom plate. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://electrolux.com/ Customer Service 1-800-896-9756
Electrolux Home Care Products – North America
P.O. Box 3900 Peoria, IL 61612
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jul 15, 2008
Anonymous
SOURCE: beater bar on Dyson upright won't turn when handle is lowered
I have finally fixed my sister's dyson dc 15 beater bar problem. It was just 2 tiny broken wires connect to circuit board lead to the beater bar. The wires broke where they go through the black rubber gommet. You need a torx screwdriver tx 15 to remove 2 plastic covers to access the wires. When looking at the front of the vacuum, the gray covers located on the right side of the vacuum. 1 big cover with a black rubber gasket and other small gray cover is on the rotating ball area.
This my new year resolution is to warn people not to buy Dyson vacuum cleaner ( Junk) design to break down! Shame on you Dyson!!!! Save your money find good old vacuum cleaner with metal parts.
OLD IS IN NEW IS JUNK!
Happy New Year!
Posted on Jan 01, 2009
Anonymous
  • 715 Answers
SOURCE: The brush isn't turning on my Kenmore progressive
replace the belt
Posted on Nov 05, 2009
mc1bean
Mike Cairns
  • 3053 Answers
SOURCE: Kenmore 31913 Progressive Direct Drive
Hello, siboneyam
I was trying to help you out here. Maybe this will help some? I was going back to some customers that asked questions in the recent past and even farther back. It appeared that no one answered some of them, So, I thought I would take some of my own personal time
to see if I can help. Even though this a Informational site may not have your exact model or brand, But this site will help you a lot. Here is the site link about everything you want to know about vacuum cleaners and possibly yours, from repair to trouble shooting it.
http://home.howstuffworks.com/vacuum-cleaner.htm
Please if this helped you at all, if you can find the time and in your heart to rate my help and some kind words written would be appreciated for my free help, I would appreciate it. Like I said I just tried to help, If anything this is good information for future problems. If you felt that my free help was a waist of time for you, I'm sorry.I do not get paid to help people on the site, I do it cause I like to help.
Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive, Appliance, and Electronics. Drop In anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 30, 2011
Anonymous
SOURCE: free instruction manual for bissell 4104
I've found step by step video demonstrations for cleaning, belt replacement, basically maintenance of different appliances on "YOUTUBE" you might want to check it out. Just type in Bissell 4104 beater bar replacement. Hopefully there will be a video showing you exactly how to replace it properly.
Posted on Jan 04, 2012
1helpful
Beater bar not turning
need new belt remove bottom cover to replace it
Caught fridge of a blanket in vaccum. Turned off and remove object. Now beater bar does turn. How to fix?
Sounds like the belt either just slipped off, or is broken.
It's normal when the beater gets jammed.
Can you spin the beater easily?
Beater bar stopped working
Here is one of my Tips on the problem you are describing:
www.fixya.com/support/r6311178-vacuum_brush_bar_not_spinning
If you have further questions, just let me know.
Good Luck!
Jim
The drum is not turning when I the vacuum is on. I have good suction. What should I do?
by drum I take it you mean the beater bar on the bottom? I would check the belt and probably replace it. remove the screws holding the very bottom of the vacuum on and remove the access plate / cover. you should see the belt or whats left of it.
2helpful
2answers
My roller do not spin
There is also a circuit protector which trips if something gets caught in the roller, so that might be the problem. There is a very small red button on the right side at the bottom of the vacuum (IT'S VERY TINY), and you just push that in and it will reset the circuit.
2answers
Handimate doesnt spin!
try ajusting the height if the beater bar also check the belt and motor
somtimes **** gets stuck in the end bearings and add resistance to the beater bar slowing it down remove beater bar abd check assemby for thread and **** build up
7helpful
3answers
The beater won't turn
Un-plug the vacuum.
Turn the vacuum cleaner over and pop off or unscrew the bottom plate. The most common things are broken belt, clogged beater bar (usually hair), bad beater bar bearings, or the beater bar and belt is just plain worn out and needs replacing. If the brush nubs are very worn, replacing the belt alone won't help much.
Clean as much debris, hair etc as possible out of the unit. If you have a can of air like the type used to clean computer key boards, blow out the area and the motor if possible. Do this in a ventilated area or somewhere where it will not mess up your house.
Open Questions:
Top Kenmore Vacuums Experts
Marvin
Marvin
David Shaub
Mike
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
