Question about Dacor Ovens
Dacor wall oven
SOURCE: dacor cps130 wall oven f1 error
According to the manual, this is an element relay circuit failure. Call the tech.
Posted on Jun 15, 2008
SOURCE: Dacor error codes
HI. the F-1 code is a System Watchdog Circuit failure code.
Press "Cancel", if beeping continues after 30 seconds, replace the main control board (also called clock or ERC).
Concerning the F-5 code. This is an oven temp sensor failure code. have it replaced asap. ((Check the wiring leading to and from the control and sensor for cracks and fouled structure. if the wiring is bad, replace the harness as well)),
Posted on Aug 01, 2009
SOURCE: oven beeping
yOU NEED TO CHECK THE FAULT CODE F1 MOST LIKELY THIS IS A STUCK BUTTON . HERE IS THE DACOR MANUAL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Aug 21, 2009
SOURCE: Dacor double oven, lower oven works fine, upper
I had the same problem after auto-cleaning my oven just before Thanksgiving. The cause was overheating...and the tripping of a heat sensor switch.
The switch (reset button) is located about 3 inches behind the door locking mechanism.
Removing the front panel (4 screws) that the door lock sticks through exposes the switch. Just push the little red button & your are back in business!!
Posted on Nov 27, 2009
SOURCE: turn off the timer on an old imperial st george
I have this exact same oven and this "feature" annoys me no end. To turn it off ... turn the clock dial to PAST the time that the timer dial shows. EG: If your timer dial is showing 6, turn the clock dial so that it rolls past 6 o'clock. This will pop out the timer dial and thus turn off the timer, allowing you to use the oven normally.
To stop accidentally pushing/turning that timer dial, I removed the knobs. Good luck.
Posted on Oct 03, 2010
