Clean the float bowl.. Even the efi systems have a float bowl which are prone to sticking from bad fuel. Ps. Use supreme gas only with zero ethanol . Ethanol eats your gas lines and will End black specks into your fuel filter. The higher the percentage the worse it is. And add stabilizer like seafoam. Check your fuel filter, and for crushed fuek line, and failed primer bulbs... these are all common issues.
SOURCE: Runs for 30 sec then stalls
go to ebay and fine yourself a cheep fule computer there about £30 second hand i think yours has just packed up and its making the bike run very very ritch
SOURCE: Why is it hard to steer a 2009 25 HP evinrude etec?
Hi Pablo:
I'd be looking for corrosion at the rotating bushing. There should be grease nipples to get lube into it. Grease, and lots of moving it should loosen it up.
This is a 2 stroke engine - an outboard motor?
Two strokes are quite robust. The usual mistake people make with these engines (think of chainsaws, lawn mowers and hedge strimmers..) is to use car engine oil instead of the correct two stroke oil. Motor oil is completely incorrect and fouls the spark plug.
The other fault is to mix fuel and two stroke oil in the wrong ratio. Most chainsaws etc .. use a mix of 25:1 Too much oil causes oiling and misfiring of the plug. Too little oil causes excessive and fast wear.
Your engine starts up. That tends to suggest that everything is working ok up to a point.
However, look on the following link which deals with an overheating problem for that engine:
http://www.etecownersgroup.com/post/25hp-etec-problem-6107593
