SOURCE: Horizontal Lines On Screen
horizontal lines = horizontal sync off . mitsbishi always seemed to have this problem .. on the older sets I would take the back off and inside deep on the board i would adjust a pot and sync it right .... and never had a recall, maybe your newer model has this too .. this little control,
but its a horizontal sync problem.
if no change the horizontal processing ic.
SOURCE: Fuzzy line going right down right side of Sony Laptop VGN-CS26g
or may be the strip connected to the lcd may also get problem.
@www. sangeethmaaza . com
Testimonial: "Thankyou again for this, I feel that the computer is not constructed with the best materials, as this is another problem after just replacing the cooling fan. Disappointed for the money spent on this computer, as we thought it would last longer, thanks again, this is appreciated. David"
SOURCE: 46 inch Sony flat panel lcd has vertical red and
If the screen works for a short while and then completely fails once the TV warms up you have a problem with the main unit video board or the LCD control logic board. Most often if the picture cuts out but audio continues to work the logic board is over heating and should be replaced. However if the picture cuts out and audio shuts off as well then its your video input board.
SOURCE: my sony bravia kdl-46v3000 has a green line
It is the lcd panel failing, the same as mine. See link
infofrobetterbuys.blogspot.com
