Question about Makita Saws
My makita saw how do i adjust carborator - Makita Saws
Posted by Wendy Howard on
3 Related Answers
Curt_W
Curt Whitney
  • 60 Answers
SOURCE: what tool to use to adjust a chain saw carborator?
generally you should take it to a repair shop, as recommended in the manual. Those settings are set by mfr. Usually also, if you can get to them, use a screwdriver.
Posted on Apr 19, 2009
hunter19_46m
Curtis Sewell
  • 7482 Answers
SOURCE: PLEASE, Need carborator. Lo/hi adjustment
Hi mkyhl...
Before you remove or try to adjust your low and high speed jets you should always count the number of turns it takes to lightly seat the idle mixture screw and high speed needle adjusting screws.
Be sure to write the number of turns down on a piece of paper so you will know how many turns from the seated position to open the jets when you go to reinstall them, or if you remove them for cleaning or replacement.
If you have aready tried to adjust them then the adjustments below should get it running for you for final adjustment when warm.
Normally you will adjust your idle jet to 1/2-3/4 turn open from the bottom seated position.
Then you will re-adjust the low speed of the engine when the engine is warm by turning the idle screw in or out till the engine runs smoothly at idle speed, around 1200 RPM.
The high speed jet is adjusted to 1 1/2- 1 3/4 open from the bottom seated position, after the engine is warm.
Then re-adjusted by turning the High Speed jet adjustment screw in or out till the motor runs smoothly at high speed.
Alway use the "lightly seated" method if you have not changed the screw settings.
Please take time to rate me
Posted on Sep 05, 2011
How do I adjust the carburettor on my Makita DPC6200 saw
You only have to adjust it a small amount. Ring Makita tech on 01908 210710 they will help you.
Mar 18, 2014 • Saws
Saw stops at predetermined stops but wont lock anywhere else
If the handle wont lock down the linkage could be out of adjustment. Look under it and you can see how the linkage works pretty easily or if it's broken. You can view a breakdown and makita.com or call Makita direct at 1-800-462-5482. they can direct you to tech from there.
2helpful
MAKITA #2703 table saw 10'' to rise and lower blade it
i would say the table is twisted then, strip it down first and if you need to "bend!" it back so it works
1helpful
How do you set up a carb on makita chain saw
You provide no manual, I chose a "DCS34" a link follows: http://www.makita.ca/data/upload/tools/DCS34%20F-E.pdf
It lists no starting point for the "H" and "L" needle valves, I recommend 1.5 CCW from lightly seated. then tune for performance like this:
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
Clean the air filter and spark arrestor; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run. If the saw cannot exhale it cannot inhale.
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
1helpful
Hi, oil is flowing freely from the holes at the front of the saw.
Did Makita give any oil pump adjustment? Most gas saws have them. Underneath below the oiler hole.
I am going to allow this to close we can still talk to one another.
Lou
My makita sliding mitre saw is off a few degrees How do I adjust...non laser...10''
move the blade until it is square to the fence then loosen the screws on the table with the degree increments and set to zero.
1helpful
Makita 5012B chain cannot be tightened
some chainsaws have different knotches where the bar locks onto the saw. loosen the nuts and see if you can move the bar.
Saws Logo
Top Makita Saws Experts
ray gallant
Parson's Repair...
Parson's Repair...
Are you a Makita Saw Expert? Answer questions, earn points and help others
