Question about Acer Tablets & eReaders
I can not set up google home on my acer tablet
Posted by Aleksandra... on
My Acer tablet keeps stopping and says it's not responding do you know what the trouble is
Afriad the Games have bugs you go to the Google store and download CCleaner and run it.
How do I get my acer tablet to work it says ui system has stopped
The problem is with the Google search engine not being compatible with the User Interface and an update failed
Delete your Google search and re-install the latest from the Google store.
If you still have problems you may wish to try the following at your own risk
Settings > More > Application Manager
change to All
Scroll down to the Google App and select it
select "Uninstall Updates"
If it asks to install a factory default, agree to that
I have no clue what google account was previously synced with my acer tablet...how do i get passed this question during set up?
create a new gmail account at www.gmail.com to use the google play store and use this instead of the unknown one .
I'm trying to reinstall a game on my Acer tablet my daughter did something and she can't remember but it's coming up with failed to extract resources needed b112cpp
it appears the google services app may need resetting (android settings > app manager > google services > clear data) this will reset the tablet's memory of whats installed until the playstore app is opened again if it fails let me know
How can I reset my tablet?
    1. Here's how to execute a factory reset:
      1. Turn your tablet off and remove the SD card, if there is one.
      2. Press and hold the combinations below until you feel the device vibrate: Power button + Volume up and down (if there is a physical Home button) Power button + Volume up + Home button (If there is a physical Home button)
      Forgot your tablet's password? - TechAdvisory.org
      www.techadvisory.org/2013/03/forgot-your-tablets-password/
    Feedback
  1. Forgotten Pattern, PIN or Password on an Android device
    acer.custhelp.com/.../forgotten-pattern,-pin-or-password-on-an-android-...
    What can I do if I set a Pattern, PIN, or Password on my Lock screen but forgot it? ...If you do not have Android Device Manager installed, the tablet must be reset ...
Problem with V. 811 Onda Tablet
hi Akram.
this is all i could find out.
When the tablet is turned off, keep home button pressed.
Now turn on tablet while still holding the home button.
When white android figure appears, release both buttons.
You will get into recovery mode, you can select "restore factory settings" there.
Download the right firmware here: ONDA
Extract the content to the root of your sd card (since you cannot use your tablet, i suggest using a cardreader + pc or another tablet? or try to hook your tablet to the pc and hope it recognizes it)
There should be 5-6 files now on your SD card.
Turn on tablet while holding home button, untill white android figure appears then release.
It should update your firmware now...
or you could try this link on how to do a hard reset.
but do so at your own risk.
Onda V811 hard reset format factory mod recovery rom install ..
or try this link for more info.
hard reset tablet onda v811 Google Search
or this one.
811 Onda Tablet logo screen white Google Search
Tablets & eReaders Logo
Top Acer Tablets & eReaders Experts
EKASYS IT SERVICES
EKASYS IT SERVICES
NOEL
NOEL
Are you an Acer Tablet and eReader Expert? Answer questions, earn points and help others
