SOURCE: Boat engine 1995 Johnson Outboard 70 HP
Ihave a 1991 70 hp Johnson outboard thats hard to start the first time but starts good after that. Seems to be flooded. Starting rpm seems to be low.
SOURCE: oil mixture for a 70 hp Johnson boat motor?
If it is a 2-stroke motor than gas:oil ratio should be 50:1
SOURCE: 1974 Johnson 70 hp outboard, quits on acceleration.
It sounds like your motor is starving for fuel. At an idle, you have adequate flow to keep the engine running. When you call for more fuel...you sputter and quit. Could be a clogged filter or trash in the line or in a jet. Yes you will have some air in the bulb, but not a great deal. You could be sucking air at a hose connection (loosing some prime)...try this, start the engine and slowly accererate, have someone pump the bulb as you accelerate, see if the engine works properly while doing this test.
SOURCE: Does an 85 johnson outboard motor 15 hp have
breaker/maker. set @ 020" @ the highest point but what is you're real problem. Run only champion spark plugs. We spenta dAY @ omc'S SERVICE CENTRE BEING SHOWN WHY. tHEY KNOW BEST!!
SOURCE: I have 1987 Johnson 20 hp outboard motor and need
The g/box in your motor holds about 1/2 litre of oil.It comes in usually 1 litre bottles.Squeeze it in the bottom hole with the spout fitted to the bottle untill it comes out the upper hole and then quickly put the screw plugs back in.Hope this helps
