Radio Communications Logo
Yuri Khomchuk Posted on Apr 22, 2018
I need help with motorola t41 the radio can receive bat not accept the signal from another redio
2 Related Answers
Anonymous
  • 6966 Answers
  • Posted on Nov 21, 2007
SOURCE: Cannot Receive a signal on either of my radios.
Hi again,
It would seem that you posted twice. Here is the link to your other post with my response.
Cheers.
Anonymous
  • 3 Answers
  • Posted on Apr 29, 2009
SOURCE: my motorola radius GM 300 can't receive signals.
check your crystal 44.645 ,near ic receiver system
What is the redio code for ford firesta 2007
HI Aaliah
In order to get the radio code you need first the radio serial number,
then you will start from there.
the radio serial number is printed on sticker on the side of the radio.
Good luck.
TURN ON MY FM REDIO ON MY PC
FM radio? OR Wireless? If you post the Make, Model of Laptop and the OS you are using it would be helpful.
Can two different style motorola 2 way radios be changed to same frequency
Hi Kate,
The short answer to your question is: no, or "not readily". Here's why:
The Motorola 4900 radio operates in the FRS (family radio service) and GMRS (general mobile radio service) in the UHF band. This radio will work with any other FRS / GMRS band radios (no reprogramming of transmit and or receive frequencies is possible for these radios). The trick is that the numbering of the channels may differ from brand to brand ie: Ch1 on your Motorola may not necessarily be Ch1 on a Midland radio or other brand. A complete list of the frequencies and channel assignments for FRS /GMRS can be found on Pg. 17 of the manual. It is important to note that without a valid GMRS license, you are prohibited from transmitting on the GMRS only channels (Ch 15 through Ch 22). The combination GMRS/FRS channels (Ch1 through Ch7) and the FRS only channels (Ch8 through Ch14) are for individuals and family members that do not have valid GMRS licenses. If this is you, you should limit your transmissions to Ch1 through Ch14 only, as FRS does not require a license in the US. Unlicensed use of GMRS only Ch15 through Ch22 can result in fines and imprisonment if caught by the FCC.
Further complicating the issue are the so called "privacy tones". This is simply a very low or "sub-audible" frequency that is sent whenever transmitting. Motorola calls these "Interference Eliminator Codes". When another radio receiver is set to listen for a particular privacy tone, it stays silent until a transmission with the exact same privacy tone is detected. Again, these tones are listed in no particular order, but are generally listed as 1, 2, 3, etc. or a, b, c, etc. instead of the actual frequency in hertz. You can selectively set your radio to transmit & receive one of the 38 codes or, set the code to "0" to communicate with radio that do not offer these privacy codes - or does not use the same frequencies for these codes. You can read more on Motorola's codes on Pg. 19 of the manual.
The Motorola CP200 radio on the other hand is a commercial radio, and requires computer programming with Motorola software. The CP200 is offered as both Low & High sub-banded VHF and Low, Mid & High sub-banded UHF radios. You would need to have a CP200 that is designed to accept the Mid UHF band (438Mhz - 470Mhz) frequencies in order to program the 462Mhz & 467Mhz FRS / GMRS frequencies into it. The final obstacle would be what is called "FCC Type Acceptance". The CP200 is probably NOT Type Accepted for transmitting FRS/GMRS frequencies, and as such the Motorola dealer doing the programing might balk at putting them in. You can read a spec sheet on the CP200 here.
I hope this helps & good luck!
2helpful
2answers
I need to download the owners manual for the motorola mr355r 2-way radio.
iam collins ,iam using motoroal v360 for 3 good years.bat is now restarting and freedownload v360 software09c56d4.jpg
1helpful
I can't get the radios to communicate with eachother, they have power and chirp when I press the talk button but nothing is being received.??? They look like the EM1000 model of Motorola radios. The FCC...
These are multi-channel FRS / GMRS radios. In order to receive transmitted signals from the other radio, they both must be set to the same Channel and the same Interference Eliminator Code. One without the other will keep audio from being heard on the receiving radio.
I suspect you need to refresh yourself with the radio's controls and settings. If you have lost the manual, you can get a copy free of charge from Motorola You'll need a free program called Adobe Reader to view it.
Once you have everything - look at the right hand side of page 1 for "Talking and Listening" followed by "Menu Options" to set the radios up correctly. Keep in mind that if VOX is selected, and there is sound near both radios, they both will transmit at the same time - since the radios receive OR transmit at any given time, no audio will be heard from either.
Please rate this reply if helpful & good luck!
Radio fades in and out
ck antenna lead from redio to antenna make sure conncetions are good.. my have internal radio concens
My motorola radius GM 300 can't receive signals.
2answers
Will a Motorola TalkAbout T5320 transmit to a Motorola TalkAbout T5530?
Hello Blindmaster,
Check the Continuous Tone Coded Squelch (CTCSS) settings on all the radios. (Note that some manufacturers refer to this feature as a “Privacy Code” or “Quiet Code.” The actual name of the feature may vary.) This feature encodes a low-frequency signal on your radio transmission. This signal is below the range of human hearing but can be detected by other radios. When the CTCSS feature is active your radio will ignore any signal that it receives that does not have the proper tone encoded on it.
In order for these radios to communicate, all of the radios need to be on the same channel and have the same CTCSS code programmed or the CTCSS feature must be disabled.
I suspect that CTCSS is activated on your T5530s but is not enabled on your T5320. This would result in the situation you describe.
Also take note that when using different brands / models of radios to communicate with one another that the CTCSS code numbering scheme may not necessarily be the same from radio to radio. For instance, CTCSS code “4” on the Motorola TalkAbout series actually corresponds to code “A” on the Motorola Sport models.
Best Regards,
Agent Ken
Go Ahead. Use Us.
Fixing my radio
It is possible that your Motorola FR60 though on the same channel/frequency have different CTCSS settings. CTSS is also known as Interference Eliminator Code or Coded squelch, Private-Line, PL, Quiet Call, Channel, Guard, etc. What needs to be done is to set both to the same code setting on the settings/menu. Turning the code/CTCSS OFF would also serve the same but allow other radios (without CTCSS) to be likewise received/heard.
If they are already on the same code setting and still no receive audio, it is possible a fault on the squelch, receive/audio circuitry or even the speaker itself which of course would require hands-on/in-shop service.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Hi again,
Cheers.
Top Motorola Radio Communications Experts
eradiostore
eradiostore
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
