Televison & Video Logo
Question about RCA Televison & Video
Rca tv pld50a45rq tv screen has a shadow on the left side
Posted by tedd reed on
Ian Njogu
    Sergeant:
  • 165 Answers
If your RCA PLD50A45RQ television has a shadow on the left side of the screen, it may be caused by a problem with the internal hardware of the TV. Here are a few things you can try to fix the issue:
  1. Check the cable connections on the back of the TV to ensure that all cables are securely plugged in. This could be the problem if the cables are loose or not properly connected.
  2. Check the settings on the TV to make sure that the picture is not being stretched or distorted in any way. This can cause a shadow on one side of the screen.
  3. Check the TV for any physical damage to the screen. If the screen is cracked or damaged, it can cause a shadow on one side of the screen.
  4. Check the backlight of the screen, if it is not working properly, it can cause a shadow on one side of the screen.
  5. If you have tried the above steps and the problem persists, it may be best to contact RCA customer service or a technician for further assistance.
  6. It is also possible that the problem is with the T-con board or the LCD panel, in this case, it is best to consult a technician to check the TV and possibly replace the damaged component.
It's important to note that if the shadow is persistent and appears even when the TV is turned off, it could be a hardware issue that requires service or repair.
Posted on Jan 14, 2023
  • Larry Jan 16, 2023
    Do you realize you're answering a 5 year old post?
5 Related Answers
Anonymous
SOURCE: shadow image acrooss screen
THIS IS TUNNEL PROBLEM
Posted on Jan 23, 2008
Anonymous
  • 128 Answers
SOURCE: Blurry on left side of the screen. Shadowing in different colors.
Try this website. It is the Hitachi support website. http://www.hitachi.com/GlobalSupport/ContactUs?form_type=global_support Hope this helps :)
Posted on Jan 28, 2008
schwarez
SOURCE: Left side of television just started having a shadowing problem?
I have the same problem and was told by a technician that I need to replace the light engine. Probably around $ 700.00.
Posted on Feb 08, 2008
Anonymous
  • 822 Answers
SOURCE: 3 horizontal lines across screen and triple shadow on left side
its a LCD connectors. re-connect it properly. some loose connection.
Posted on May 25, 2009
Anonymous
SOURCE: shadow on upper left corner
A little late and you've probably already solved it or are just living with it or are disgusted with it and have discarded the tv. But, in any event - here we go. The "light tunnel" bends the light toward your screen. At the beginning of that tunnel there is a plastic lens. The lens is secured with four little feet that a part of the lense. The lens is flat on the side closest to the screen. It fits on the end of the light tunnel closest to the light. The lens probably has a burnt spot. Probably the burn is caused by excess heat which is either a result of a fan failure or a one-time situation where the power went off while everything was hot and there was no cool down cycle. Another item to look at is in the light path before that lens. There is a small "window". It's actually a very thin piece of glass (about 1"X1") held in place by a horseshoe shaped clip and one screw. I think that glass has the purpose of keeping heat away from that plastic lens. If that glass is broken I think you'll have a heat "leak" and the plastic lens will continue to get worse.
Posted on Aug 05, 2009
Samsung 46 LCD has shadow on left side of screen when TV is turned on
I would to see a picture of what it looks like. What you are describing sounds like a faulty LCD panel tab. Samsung LCD panels are known for this problem.
My RCA Scenium looks like there is a shadow of another channel on the screen
I am scraping out my tv all boards are good the tv played great just wanted a wall hanger if you need a part call me 270 589 8074
3" shadow on left side of screen
watch for speakers being to close to the tv. if a speaker has a big magnet on the back of it, it will cause it to have the shadow and then it will turn green. so make sure there is nothing with a magnet close to the tv because it will ruin the tube on the tv.
3" vertical shadow on left side of screen
Either (on this plasma) a damaged/bad sustain board for left side of screen or a problem with the Display panel--set by model number is 5-6 years old so may or may not be worth fixing.
My 52" RCA P52937SG screen
the part is called the convergence ic. replace those ics.
1helpful
I have a HDTV 524159 RCA, it has an hour-glass effect on both directions. On the left side, it hour-glass inward with red and yellow stripes and on right side blue and light blue stripes. It hour-glass...
Hi Sandy, the problem with your TV is called "convergence". It can be a problem with the convergence board or more likely in this model in the power supply or deflection circuits. Unfortunately, troubleshooting by a technician is required.
RCA HD52W59 Crooked Convergence
Convergence power supply needs to be rebuilt as its no longer available new. You can get the board rebuilt at the following link and its fully guaranteed.
http://servicemanuals.vstore.ca/
Blue Shadow
YOU CAN TRY TO ADJUST THE COVERSION POINTS USING THE MENU OPTIONS IF THIS DOES NOT WORK THEN YOUR CONVERSION CHIPS HAVE TO BE REPLACED IT COST AROUND 200 TO 250 DOLLARD
3answers
Top RCA Televison & Video Experts
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
