If you mean the glass dome of the bulb has broken leaving only the metal bulb base, you will need a medium size long nose plier to grip the edge of the bulb base, you can then gently rotate counter clockwise to remove.
ENSURE THE APPLIANCE IS ISOLATED FROM THE MAINS SUPPLY BEFORE ATTEMPTING THIS !!! PULL THE PLUG !!!
Testimonial: "Thank you .It is not the dome on the bulb,it is the glass cover that protects the bulb."
SOURCE: the inside fan cover started peeling and broke
its the fan inside the oven cavity on top, its part # AP3671492 and is a G.E. part# called the Cover,Stirrer Fan still manufactured
