Question about Garden
Ratio for 2 stroke mi - Garden
Posted by george smith on
Bill Boyd
    Top Expert:
  • Garden Master
  • 53,816 Answers
If you are asking the oil /fuel ratio for a 2 stroke small engine. not being told the size, make or model makes an answer impossible
however Stihl have a special 2 stroke oil that is mixed at the ratio of 50:1 and that will cover all ratios from 20:1 to 50:1
Saves having different cans for all of the engines that can be a workshop
Mixed correctly it works well and if you want just the one fuel can that includes 4 stroke engines
the 50:1 ratio makes for good upper cylinder lubricant in those engines as well and you will not even see it smoke
Posted on Apr 21, 2018
5 Related Answers
Editor925
Dean
  • 285 Answers
SOURCE: 2 cycle oil to gas mixture ratio
40:1 for a McCulloch 3214.
Posted on Jun 24, 2009
MNfisherman
Nate Stansfield
  • 11896 Answers
SOURCE: What is the gas and oil ratio and is it 2 stroke for sx-135
40:1
1 gallon fuel to 3.2 ounces 2-stroke oil
Posted on Sep 23, 2009
senna_hoy
  • 6 Answers
SOURCE: How to refuel Vintage Scooter 2 stroke, 125cc engine (Oil ratio)
Older Vespa is 2% mix = 50:1. Get the measurement cup made for Vespa
Posted on Jan 09, 2010
Bruce Hathcock
  • 3600 Answers
SOURCE: Fuel Mixture Ratio Is it - 25:1 40:1 50:1
not sure if yo are changing the jets out but if your using the original screws and jets screw both screws in till they stop then turn 1 and a half turns out they try starting if it kicks and won't run then turn each screw another 1/2 turn out try starting if it runs rough adjust the gas jet a little bit till it runs smooth once it warms up give it full gas and you should get just a slight puff of black smoke to be set right, if it's too lean it will get hot and will be hard to start if it dies, if that happens then give it extra gas. once warmed up it should idle without dyeing if it dies adjust the idle screw up 1/4 turn at a time till it runs at idle without holding the gas trigger, be sure you replace the in line fuel filter and fuel line first then clean the air filter before doing any adjustments. most problems are caused by plugged fuel filter due to ethanol in the gas.
Posted on Mar 10, 2010
Testimonial: "sweet bro thanks 4 the extra tips as well"
yz-maniac
Danny
  • 127 Answers
SOURCE: 2 stroke ratio
32:1 to 40:1 is fine.if you go any more than 40:1 your just wasting money and will foul plugs! any less than 32:1 and the top end is not protected.....
Posted on Jun 10, 2010
What is the gas/oil ratio for this chainsaw? Is synthetic oil okay to use in it?
Generally 2 stroke engines work on a ratio of 50:1
100ml of 2 stroke oil in 5L of petrol.
Use good quality 2 stroke engine oil for the mixture, Stihl and Husqvarna both have high quality engine oils, designed for more efficient lubrication and emissions quality.
Mar 28, 2016 | Garden
What is the fuel oil ratio per litre for a husqvarna 535rxt strimmer
If it is 2 stroke, take petrol /fuel and mix it with preferably synthetic2 stroke oil.
Ratio is usually 10L petrol mixed with 200 ml or 2 stroke oil, that is the best result, used it on my chainsaw, strimmer, moped, working for years without a glitch.
Jul 20, 2015 | Husqvarna Garden
What bis the ratio for a 1635a 16 inch 2 cycle
I got this from the McCulloch.com website. "Products with two-stroke engines, the petrol must be mixed with two-stroke oil. McCulloch recommends Outdoor Accessories two-stroke oil. The petrol/oil ratio must be 50:1"
Oct 05, 2013 | McCulloch Mcc1635a 16-inch 35cc 2-cycle...
What is the 2 stroke petrol mix for a garden strimmer, Ryobi 25cc PLT 2543 please?
hi there keithprobert
the ratio to use if using top quality 2 stroke oil is 50:1 that is 20 mills of 2 stroke oil per 1.0 litre of petrol that you mix.
but if not using top quality 2 stroke oil use ratio 25:1 that is 40 mills of 2stroke oil per 1.0 litre of petrol that you mix.
cheers pauly46
dont forget the thumbs rating
Jun 02, 2011 | Garden
Need gas misture ratio for trimmer SRM2501
pauly46 here
the ratio you should use is 50:1
that is 20 mils of 2 stroke oil for every 1.0 litre of petrol that you mix
so if you want to make 2 litre mix use 40 mils of 2 stroke oil , then add 2 litres of petrol only and give good shake
note use good quality 2 stroke oil , such as sthil or husqvarna oil from your outdoor power shop
but if using general 2 stroke oil from a garage use 40 mils of oil for every 1 litre that you mix
this ratio is 25:1 this mix is on the richer side
cheers hope this helps
May 01, 2011 | Echo Garden
I have a homelite f2020 series petrol trimmer i would like to know the petrol and oil ratio mixture please
I use 50:1 with Sthil 2-stroke oil in ALL my 2-stroke equipment. This ratio does not smoke at all, and does not foul plugs.
Never had a problem yet. At this mix ratio, you can also use it in 4-stroke engines, which means you only need 1 fuel can on site. Also eliminates the possibility of using the wrong can to fill the trimmer.
Jun 16, 2010 | Homelite Mighty Lite Lawn Trimmer
What is the 2 stroke oil to fuel mix?
The fuel to oil ratio tells how much fuel and oil to mix for a given 2 stroke engine. It can be different depending on the recommedation from the manufacturer. NOT ALL 2 STROKE ENGINES USE THE SAME RATIO. You have to know the manufacturer recommendation for your engine.
May 20, 2010 | Air Tools & Compressors
WHAT IS THE CORRECT FUEL TO 2 STROKE OIL RATIO FOR A 2006 KAWASAKI KX85
It all depends on what type (and brand) of two stroke oil you're using. For example, some non-synthetic two stroke oils are supposed to be mixed at a ratio of 20:1. While most synthetic oils are designed to be mixed anywhere from 36:1 to 100:1. Your best bet is to follow the advice of the folks at your dealer as to the type of oil to use - and then follow the recommended mixing ratio as detailed in the oil manufacturer's instructions.
Nov 07, 2009 | 2006 kawasaki KX 125
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
