SOURCE: freezer cold, not fridge
8 to 10 hours depending on how much warm items you placed inside to cool down. Make sure your fresh food section settings are set for medium. I'm not sure from what country you are from but a standard setting for both freezer and refrigerator should be set both mid way. For example (not that you need help here) 1 being the warm being the warmest and 10 being the coldest. Now some companies go like 1 being the coldest and 10 being the warmest. But 5 should be set up for first time start ups no matter where you are from. Thanks, Sea Breeze
SOURCE: When I moved, the cardboard backing on the bottom
yes that panel directs the air flo for the condenser fan that helps keep the compressor cool and moves the air over the condensor coils you can use card board just make sure you put air holes so the fan can pull air in
SOURCE: how do you remove the back panel of a PSC23NSTSS
Behind that cardboard there will be a drain exit that fill a pan that the fan blows over. But the correct way would be through the entrance and that is found inside the rear wall of freezer. Let me see if I can find some illustrations. Sea Breeze
SOURCE: freezing food in my refrigerator
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
