GZ-MS130: 1)struggle to register product online - don't know where to find the product key in the box nor on the warranty.
2) .pdf manual and instruction book are not the same as software - need to know how to save, edit and then convert file to email format
Please advise
Paula Bierman
SOURCE: JVC Everio GZ-MG130U
Format the hard drive, one of the files on the hdd are corrupt, I had the same problem and I formatted the hard drive on my camera and the computer would read the camera again. It sucked though because I lost all my pictures in the process but that was the only way to get it to work. I had tried everything else before that.
SOURCE: JVC Camera without software to burn to dvd
i have vista and this worked for me
make sure cam is off and usb it to ur pc.
turn on cam and chose back up to pc
go to computer and open the foloders on your cam
minimize the page and drag the sd folder to your desktop
transfer files to windows movie maker
edit publish to whatever you want(dvd)
if you have vista you dont need the camera software,in fact the software sucks neway
SOURCE: can't access/copy video files on JVC gz-mg37aa
do not format it in any case bcoz in that case u will lose ur data all videos try using it on vista see if it helps do not format it in any case tell me th eresults i will help u more
SOURCE: Need the software/driver for the JVC GZ-MG50U URGENTLY!
Try this, it is for Vista,
http://www.cyberlink.com/oem/jvc/cds/enu/index.jsp
SOURCE: Everio GZ-MG21U, replacement software download?
If you have windows, you can use FFMPEG to convert the files into any format you want and then windows either windows movie maker or other software. On my mac, iMovie will automatically recognize the camera and covert the files!
00-0000-0000000FF1CE
or
HKEY_LOCAL_MACHINE\Software\Microsoft\Office\12.0\Registration\{91120000-0011-0000-0000-0000000FF1CE
4.
If there is more than one registry entries or subkeys that reference
Microsoft 12.0 registration, open up each subkey, and then identify the
product by the ProductName value data until you locate the subkey for
the product which you want to remove the existing product license key.
For example:
ProductName=Microsoft Office Professional Plus 2007
ProductName=Microsoft Office Enterprise 2007
5. Once found the correct registry subkey, delete the following values:
DigitalProductID
ProductID
6. Close Registry Editor.
Once Microsoft Office 2007 has been installed with no product key, proceed with the following steps:
1. In Windows Explorer, brose to the following folder:
C:\Program Files\Common Files\Microsoft Shared\OFFICE12\Office Setup Controller\Proof.en\
2. Right click on Proof.XML file, select "Open With..." in the right click menu.
3.
In the "Open With" window, select Notepad to be used to open the XML
file. In Vista, if you can't see the Notepad option, simply double click
the "Other Programs" to unhide it.
4. Scroll down to the bottom of the Proof.XML to locate the following lines:
*/Feature* *Feature Id="SetupXmlFiles" Cost="1248?*
*OptionRef Id="AlwaysInstalled"/*
*/Feature*
5. Change the AlwaysInsalled to neverInstalled so that the line looks like following:
*OptionRef Id="neverInstalled"/*
6.
Save the Proof.xml file. In Windows Vista, you may need to take
ownership and grant full access permission to yourself before able to
modify the file.
7. You can now launch Microsoft Office 2007
application such as Word, Excel, Powerpoint, Outlook and etc without
prompting for activation.
