Question about Haier Refrigerators
My haier under counter fridge is beeping. What can i do to stop it?
Posted by Mike S on
James Basile
    Habit-Forming:
    New Friend:
  • 74 Answers
Unplug & leave disconnected from power for a few minutes then replug in refrigerator & see if that restores the display.
Posted on Apr 20, 2018
2 Related Answers
Nomodo4u
Poppy Chulo
  • 863 Answers
SOURCE: an alarm beeping goes off at midnite, dont know
Unplug the thing from the outlet and that will surely stop it.  Grab you a hammer and apply force to the unit multiple times and that will surely stop it.  Use the kitchen sink sprayer and hose the thing down and that will surely stop it.
Here you go: http://www.fixya.com/search.aspx?_s=GE+7-5295+manuals
Posted on Oct 26, 2009
patm31806
Patrick Miller
  • 78 Answers
SOURCE: Why is my Haier bar fridge beeping occassionally?
Does it have a water filter? Some of them beep when they want you to replace the filter.
Posted on Feb 02, 2015
Is there any way I can delete the alarm beep when doors are left open on my new Haier fridge HSBS610IS please?
No unless you find the beep unit on the motherboard and remove it. It is a safety feature to stop food spoiling and the compressor running unneccessarily.
Dec 01, 2017 | Haier Refrigerators
Feb 02, 2015 | Refrigerators
To cold
Try 2 switch off (plug out) leave it few hour then switch on (plug in) again sometime it just error.
Dec 04, 2012 | Haier Refrigerator Fridge Personal Mini...
Hi, I have a Bosch undercounter freezer and it won't stop beeping!!! All the lights flash whilst beeping, the lights are under the super freeze button, mute button and the temperatures. If I hold...
The beeping is a signal that the fridge has not got down to, or holding temperature... You may have a thermostat or gas system fault. Check and see that the fridge has actually got cold.
Jul 31, 2011 | 2007 Harley Davidson FLHX Street Glide
Our Haier HDC1804TW counter-top dishwasher does not complete the washing cycle. It stops after 90 minutes which should be 115 minutes for heavy washing according to the manual. The washing light is...
Since mine does the very same thing, it's my guess that is the sterilising cycle as by this point it has already washed, done a short fill to remove any remaining detergent, and two rinses. I'm also assuming the second short fill is just to cover the heating element and/or to to generate an amount of steam having being heated by the element (I'm basing that assumption on the heat of the dishes at the end of end of the cycle and the heat of the water when it drains)
Mar 05, 2011 | Haier HDC1804TW Dishwasher
Haier HRF10 Fridge weird motor sounds
hi. thanks for the question. leaving the door open ,would let a lot of moisture to enter the freezer, and cause it to frost up. to clear frost. cut power to fridge, open the doors .,let thaw over nite clean up the water mess. dry the inside of fridge & freezer turn power on good to go. to stop the door from being left open .lift the legs under the front so the fridge has more weight, and it will close by self . no more doors left open. thanks the appliance doc
Sep 28, 2008 | Refrigerators
Haier HNSE05 shuts off on it's own.
Sounds like the thermostat is bad which is temp. dial.
Sep 19, 2007 | Haier HNSE05 Refrigerator With Ice Box
Refrigerators Logo
951 people viewed this question
Top Haier Refrigerators Experts
Vernon Taylor
John Tripp
John Tripp
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
