Question about Sylvania Televison & Video
SOURCE: Remote Code for Sylvania LC195SL8 TV
Yep me three. I just got a 2008 new Sylvania LCD and my remote will not work either.
I hate DirectV
Posted on Sep 05, 2008
SOURCE: Need 3-digit TV remote code--Sylvania 15" LCD HDTV
many of the dish remotes have a "scan" option. This is what the installers use. You'll ned to read the manual. Its a one page explanation.
Posted on Oct 29, 2008
SOURCE: RCA DTA800 programming codes
http://www.1800customersupport.com/productdocuments/DTA800_code.pdf
Posted on Nov 11, 2008
SOURCE: Need a progam code for rca dta800
I just tried their web site and it worked! They have the codes. www.1800customersupport.com/rca
or here is the direct link: http://www.1800customersupport.com/productdocuments/DTA800B1_Program_Codes.pdf
Hope this helps others who have had the same problem. Mine did not even come with these codes!!!
Posted on Mar 24, 2009
SOURCE: cant program direct tv remote with my new sylvania lc320slx
The remote is only programmed with only so many codes. Sadly, It doesn't hold all code for every TV made.
But you can try making the remote search every code stored inside to see if one of them will work.
Here are the instructions form the DIRECTV web site:
You may still find a setup code that works for your device by stepping through the library codes in your remote. The following instructions will help you do this.
StepNSet
Posted on May 18, 2009
Jan 11, 2016 | Sony Televison & Video
Sep 30, 2014 | Televison & Video
006,007,010,011,013,016,027,
033,035,043,049,066,087,089
Programming method
[1] Press the button of the device you want to
control (for example TV).
[2] If the device turns on, press another button,
to confirm (for example CHANNEL UP)
[3] If the device you selected (TV) responds,
you will not need to program the remote.
If the device you selected (TV) does
not respond, you will need to program
the remote
There are very rare RCA remotes, with Sylvania TV can be programmed. Just try the above codes with your present RCA remote control. If it does not help, buy the above model RCA universal remote. You will get code list and all other related documents, how to programme it or so, with the device you do purchase. OK.
Jun 14, 2011 | Sylvania 6424FF TV
May 28, 2011 | RCA (DTA800B1) Video Converter
Aug 28, 2009 | Televison & Video
Jul 31, 2009 | Sylvania LC-225SL9 22 in. LCD TV
Nov 08, 2008 | RCA RCU600M Remote Control
Aug 10, 2008 | RCA 3-Device Universal Remote
50 people viewed this question
