Question about RCA Televison & Video
SOURCE: FPA lock settings, No remote, can not power on TV
If you forget your password you can reset it. Make sure the TV is off. Simultaneously press and hold VOL< on the TV?s front panel and CLEAR on the remote for approximately 5 seconds. Enter a new password next time you access the PARENTAL CONTROL menu. Front Panel Lock 1. From the PARENTAL CONTROL menu, press the up or down arrow to highlight Lock Fr. Panel. 2. Press the right or left arrow to turn on (box has check mark) or off (box doesn?t have check mark) front panel lock. Of course if you don't have a remote that can bring up the menu I don't know how this can be done.
Posted on Sep 13, 2007
SOURCE: rca rcr860 remote manual code list
http://157.254.235.130/public/RCR860.pdf
http://157.254.235.130/public/RCR860_code_list.pdf
These are the sites for the manual and Code List
Posted on May 29, 2008
SOURCE: Toshiba 24AF44
You need the original remote controller to be able to switch input modes.Universal ones usually don't work. If you don't have the original remote and can't find it ever or if it is too expensive you can buy an rf modulator ( very cheap) and connect your dvd player, game console etc) to the modulator then connect the modulator to your antenna with a coax cable. This worked for me. It placed the connection to channel 4 and other cable channels are still working,
You can buy the RF Modulator from: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=180299245670
Posted on Oct 28, 2008
SOURCE: olevia 32 inch tv rca universal remote need a code to program
Try using code 11610
Posted on Feb 15, 2009
SOURCE: cox universal remote won't control samsung tv ln52a650 volume
This is a tough one, I can come up with possibly 2 solutions, 1 being that if the batteries are low you will sometimes lose partial control of some of the functions on the remote, and if that is not it, then I have another that this one happened to me once, The infrared on the TV was not picking up the volume button I was sitting at an angle, so everytime i sit in that chair everything works but the voulume control i have to point it right at it on direct line and not from the side...Hope this helps...Steve
Posted on Jun 13, 2009
