It normally works and we get hot water back, but not for long, a few days to a week later, the switch needs to be used again. and normally I've noticed that the water gets really hot right before it does that. Now it's happened again, but this time, the red switch will not click or push in. Any help?
Hello, Aaron -
It is time to contact an authorized repair person for your make of water heater and repair the electrical fault with your water heater. Depending upon the age of your water heater, it may be time to purchase a new one.
According to the well-respected U.S. publication, Consumer Reports, which evaluates all kinds of products, the average life expectancy water heaters are:
- electric water heater: 11 years,
- gas water heater: 10 years
- tankless water heater: 20+ years
Source:
https://www.consumerreports.org/cro/news/2009/03/by-the-numbers-how-long-will-your-appliances-last-it-depends/index.htm
Best wishes.
SOURCE: 1999 Ford Expedition 5.4 V8 Blinking Dash Lights While Driving
sounds like an earth connection ,but where ,,,,back of dash,,,battery earth,,,ECU earth point ,,try putting a drop of oil on the earth points with a conventional oil can no sprays of crappy fish oil other than that you would have to wait for it to happen again in front of a mechinic to find it,.or trade it in for a nice europeon size car with a an engine under 1600cc .5litres is a bit obscene in this day and age and price of petrol
SOURCE: 2002 Mitsubishi Montero Sport XLS transfer case issue.
The best place for a DIY manual is www.ALLDATADIY.com their info is very accurate.
SOURCE: 2000 Volkswagen Passat will not start
THIS ONE IS COMPLICATED ONE RELAY AND SO MANY PROBLEMS CAN CAUSE THIS PROBLEM
1) THE RELAY YOU ARE HAVING TROUBLE WITH ON THE FUSE BOX COVER THERE SHOULD BE A CHART OF WHAT FEEDS WHAT WHAT DOES THE LID SAY IT FEEDS
2) TRY PULLING THE FUSE TO THE SUN ROOF AND DOOR LOCKS AND REPLACE THE RELAY IF IT STAYS IN YOU HAVE A PROBLEM WITH ONE OR THE OTHER. THIS COULD BET A MOTOR PROBLEM ON THE SUN ROOF OR A DOOR LATCH PROBLEM.
WE WILL TAKE THIS ONE STEP AT A TIMEIF THIS DOES NOT WORK, E-MAIL ME AT [email protected]
IF THIS DOS'NT WORK I'LL HELP YOU THE BEST I CAN WITH OUT SEEING THE CAR. THIS IS ONE OF THOSE PROCESS OF ELIMINATION REPAIRS AND TO TAKE IT TO A REPAIR SHOP THIS IS GOING TO BE EXSPENSIVE
SOURCE: 86 bmw L7
I think your problem might be your fuel relay which is situated next to the fuse box in the engine compartment.
SOURCE: My 97 Acura 3.2 TL starts to overheat and I also
how can i fix a overheating on a acura tl 1997 3.2
Hi Aaron , I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
What is the make and model of unit. Need more onfo before I can help you.
