Question about Makita Saws
Makita 2703 table saw. I installed a coil and the motor runs but in reverse. I reversed the brushes as well as the black and white wires. It still runs in reverse. What do I need to do?
Posted by James Maher on
How to reverse polarity on a 3/4 horse electric motor
Reverse the black and white wires inside the motor.
Oct 23, 2018 • Saws
1helpful
Makita MLT100 table saw when stop button is pressed the motor switches off saw seems to be running really roughly and the the blade takes an age to stop spinning. Normally blade stops really quickly.
I can't find this saw at Makita; so, generally. Follow all safety precautions. :-)
If the saw is running rough, the first thing I'd check is the brushes for the motor, especially if it has any age. These are fairly inexpensive and will solve a lot of woes. The next thing would be to check the thumb switch, if it has one. This is the switch that allows you to pull the trigger to run the saw, if it's just a button, then check the actual trigger switch to make sure it's working properly as it probably, not always, also engages the brushes to reverse the motor for a second, to slow it down so it stops faster.
So, check the brushes on the motor, if they show any signs of wear, it's probably them. 2nd, check the switch. Please let me know and if I've helped, give me a vote up. Thanks.
May 18, 2017 • Makita Saws
2answers
I have a makita 2703 table saw. Saw would not turn on from time tio time, then just would not turn on at all. Just replaced the switch and verified no other wiring issues up to the motor.
First thing I would check are the Carbon Brushes. The are # 75 in the picture
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Thanks for using Fixya.
Jul 01, 2011 • Makita Saws
What is the most efficient way to remove and replace the switch on the Makita 2703?
there is only one way that I know of. Unplug tool and lay on its backside to expose the undercarriage of tool, remove the screws holding the switch plate on and remove box
Switch wiring for makita cut off saw
go to makita.com enter yr model # in the search bar, down load a parts breakdown, it should b there
2answers
2helpful
MAKITA #2703 table saw 10'' to rise and lower blade it
i would say the table is twisted then, strip it down first and if you need to "bend!" it back so it works
Makita table saw switch wiring
i need the owner/operator manual for a makita table saw model 12711 please tell me what steps to take to get one
Mar 01, 2009 • Makita Saws
6helpful
2answers
After much trial and error, a little smoke, and wrecking one replacement switch, I solved a similar problem with my Craftsman Cmpd Mitre saw. Different saw, but likely the same principles are involved.
If the switch is a double pole single throw switch, with one side normally open (N0) and the other normally closed (NC), and the saw has a separate wire for the brake, this will probably work.
One side of the switch should have contacts that are normally open (NO) and only connect when the switch is ON. The Hot (Black) wire from the plug connects to the wire on the machine side (red or maybe black) through this NO side. So, connect these two wires via this NO side and the saw will run when the switch is ON but will have no brake; so far so good.
There should be another wire (Not the neutral white) which is the brake wire. This gets connected to one of the connection sites of the Normally Closed (NC) side of the switch. From the other connection site of this NC side run a short "jumper" wire (of the same guage as the other wires) to the Machine Side of the NO side of the switch (same place as that Red or Black? wire above) .
What seems to happen is this:
There's no power to the machine or the brake when the switch is OFF. Turn it ON and power goes from Hot through the NO (now closed) side and the saw runs. The brake doesn't run when the saw runs because the NC switch is now open. Turn the switch OFF and the NC switch is in fact closed and power is transfered to the brake via the jumper wire from the still spinning armature which now acts as a generator (alternator?). Once the brake has done its job and the armature stops spinning there's no power anywhere until you turn the switch ON again.
Or at least that's the theory, and in my case it works; no more smoke.
Saws Logo
Top Makita Saws Experts
ray gallant
Parson's Repair...
Parson's Repair...
Are you a Makita Saw Expert? Answer questions, earn points and help others
