Question about Bernina Sewing Machines
Bernina 170 will only straight stitch
Posted by Kathy Bickel on
R.A. Ellis
  • Bernina Master
  • 12,731 Answers
How long since you've had the machine cleaned and lubed? Sounds like perhaps the selector mechanism has seized. I know this is a common issue with the older Bernina (Records) that require frequent cleanings and oiling (with good quality sewing machine oil or Tri-Flow Synthetic Lube).
Posted on Apr 18, 2018
5 Related Answers
Anonymous
  • 230 Answers
SOURCE: Bernina 1130 not catching bobbin thread
there will be a adjustment in that you should select the stiching mode and in that give the straight mode the problem will be solved
Posted on Jun 05, 2008
Anonymous
SOURCE: Zig Zag Stitch not working
THis problem occurred as I was sewing on Neoprene. I was using Gutterman all-purpose thread and a size 80 needle. Tried switching to a size 70, then to size 90. Still unable to zig zag. After inserting a test sample of cotton, the zig zag worked perfectly, so I knew it was not a mecahnical problem. I switched needles again. This time to size 90 for stretch fabric. Voila! Problem solved.
Posted on May 24, 2009
elizebeth900
  • 13 Answers
SOURCE: old bernina 830 stitching problem: tight
Sounds like you need to adjust the tension. Probably a good idea to oil this older machine before you adjust. Also look for and clean out any lint or debris in bobbin case and around foot area.
Posted on Aug 29, 2009
Wayne Buss
  • 121 Answers
SOURCE: Do I need to oil the Bernina Artista 170? If so,
- yes \-every 3-5 hours of sewing or more if you are sewing very dirty fabrics (used canvas etc)
-remove the shuttle, clean and oil the "race" where the shuttle ocellates
-remove the light cover with the off set torues wrench included with your machine
oil the needle bar, take up lefver joints and the presserfoot bar. any thing more should be done by a qualified technicial who should remove back and front covers and remove lint and dirt and then oil all the bearings
drtension
Posted on May 02, 2010
relicssmm
  • 20 Answers
SOURCE: Bernina 1080 while sewing normal stitch, stitch
What stitch to you have selected for it to do? Please check to see if it is set for straight stitch only.
Linda at Relics
www.sewing-machine-manuals.com
Posted on Jul 05, 2011
Tip
Sewing Machines How do I make a zigzag stitch
When it comes time to do your actual project, you'll want to use thread that matches the color of your fabric.
  1. Step 1 Zigzag Stitch. ...
  2. Insert your fabric into the sewing machine and depress the presser foot. ...
  3. Guide the fabric through the machine to keep the stitch straight
Zigzag Stitch iFixit
How to Make Zigzag Stitch Sewing Machine
Bernina 550 40 Triple Straight Stitch Zig Zag
Zigzag foot 0
https://blog.bernina.com/en/2017/01/useful-stitches-are-also-decorative-stitches
Bernina Sewing Machines How do make zigzag stitch Google Search
on Dec 13, 2017 | Sewing Machines
How to lengthen out the straight stitch on a 1230 bernina
Use the Stitch Length dial/lever. The higher the number, the farther apart the stitches will be.
Feb 15, 2017 | Bernina Sewing Machines
My Bernina 830 will not switch stitches. It says the number but shows straight stitch and sews straight stitch
Is it a new 830 computerized model or the older 830 Record mechanical?
If it is the 830 Record, it needs oiling--1-2 drops of good quality sewing machine oil (specifically concentrate on the stitch selector lever and oil the metal parts that move against other metal parts) Do NOT oil the cams, plastic gears, any rubber parts, ie belts, bobbin winder wheel.
Bernina 530 through 830 Record Oiling Diagram
Oct 19, 2015 | Bernina Sewing Machines
Bernina activa 210/how do i switch reverse sewing back to statight stitch
Perhaps the manual would be helpful:
BERNINA activa 210 Support BERNINA
You may want to download and keep this manual. A lot of manuals for older Berninas are no longer available.
Dec 15, 2013 | Bernina Activa 130
Bottom stitching is loose
try adjusting the top thread tension one number or letter at a time
forwards till the stitch look normal
here is 2 link for a manual
http://www.sewingpartsonline.com/instruction-manual-bernina-artista-170-and-180.aspx
http://www.sewingpartsonline.com/manuals/Bernina/170,%20180%20(Artista).pdf
Aug 22, 2012 | Bernina Artista 180
Bernina activa 210 won't zigzag and has bobbin issues on straight stitch
it's very possible that the machine is slightly out of time & needs to be service at a sewing machine shop
is the fabric & thread & needle compatable with each other?
did you use every thread guide when threading the machine?
is the bobbin in correctly?
is the bobbin warped?
Mar 20, 2012 | Bernina Sewing Machines
Linda at Relics
Jul 05, 2011 | Bernina Sewing Machines
My bernina patchwork 140 will not sew in reverse when I press the reverse button has the button gone bad the button hole won't sew ithe back stitch either?
Some machines will not do any of their automatic forwards and backwards movement type stitches in reverse, are you trying to reverse in straight stitch or a more complex stitch.
The Activa is a late model quality machine, do you have a Bernina dealer locally you could ring up and ask or take it to?
Mar 10, 2011 | Bernina Activa 140
My Bernina 830 Sewing Machine is not sewing the 1-20 stitches, only straight stitches.
If you are selecting patterns but only getting a straight stitch after making sure you have set the width, there may be a chance that the pattern camstack has split and the selector finger is stuck in the split, more common than people think,
take the top off the machine and check
Oct 23, 2009 | Bernina Sewing Machines
Sewing Machines Logo
87 people viewed this question
Top Bernina Sewing Machines Experts
Chris Wetmore
Colin Stickland
Colin Stickland
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
