Question about American Standard Home
Seat is loose, how do you tighten it - have American Standard
Posted by Ron Hall on
Steve Pack
  • American Sta... Master
  • 4,331 Answers
Posted on Apr 17, 2018
5 Related Answers
Anonymous
  • 54 Answers
SOURCE: loose Toto toilet seat
Lift up plastic caps located on ends of hindge behind seat. use flat screw driver and hold the nut under the outside toilet rim with your fingers or a pair of pliers. Do not over tighten or might crack the bowl.
Posted on Sep 14, 2009
mfraitag271
SOURCE: Square toilet seat made by American Standard Model TL 235.
This guy Allen in NY has lots of odd seats. Try him 914-963-6895
Posted on Nov 09, 2009
Lance Hill
  • 1739 Answers
SOURCE: Where can you purchase a toilet seat for a LowBoy
You can order from the American Standard website:
http://www.americanstandard-us.com/repair-parts/toilet-seats/?so=&r=10&p=1
You can also search for a retailer/distributor near you who will probably carry replacement parts. See here:
http://www.americanstandard-us.com/dealerLocator.aspx
Posted on Jan 26, 2011
SOURCE: How tight should I tighten
There is no torque value as far as I know. There should be rubber washers to minmize the chance of cracking the ceramic and to provide a water seal.
But to try to give some sort of guideline, on a scale of 1 - 10, I'd say a 6 would be about right -- or perhaps you could call that medium tight. In any event, the bolts have to be tight enough to prevent leaking -- if it leaks, you'll have to keep tightening.
Charlie
Posted on Mar 28, 2011
American standard faucet loose head
Remove the cap and tighten Philips head screw.
Nov 20, 2016 | American Standard Plumbing
9C-23H/C American Standard: Does the seat for the stem take an o-ring? I replaced the seats but the drip got worse.
There are three things to replacing a washer seat, after you turn the water off, open the valve before you replace it, most people take the stem nut out first, then putting it back over compresses it unless the valve is open.
Check the seat, this is not the rubber washer at the end of the stem. The seat is in the fixture, most can be removed with a special wrench.
Last but not least is the over tightening the valve to stop the water. Water wont stop instantly and it important to remember that. Turn the water of lightly when you are done, wait a moment to see what happens when the residual water drains. Then tighten more if necessary.
Feb 22, 2016 | American Standard Plumbing
How to tighten the seat on toilet
Put your hand around the back of the seat and you will feel the nuts. Tighten them by simply turning them.
Sep 02, 2014 | American Standard Cadet 3 Right Height...
Fix an american standard slow close toilet seat
Check the chain the goes between the handle and the flapper.
It should not be taught. If it is it will not permit the flapper to seat
properly and water will leak out. Adjust the chain length so the flapper is seated and there is just a little slack in the chain.
Aug 02, 2014 | American Standard Cadet 3 Right Height...
How to tighten an american standard toilet seat
They all work pretty much the same. Feel around the top rim of the bowl near where the tank meets the bowl you should find one bolt underneath on either side of the toilet seat. Tighten the nut under there to tighten the seat.
Oct 24, 2013 | American Standard Church Seats EL270...
Where can I buy the toilet seat hinges for an american standard plaza elisse
Go to American Standard website for customer assistance phone number.
Sep 26, 2013 | American Standard Church Seats EL270...
Loose single handle no brand name faucet
There is a little rubber icon Red for Hot and Blue for the cold on the front of the handle. Remove the rubber insert from the handle. There is a small allen screw that needs tighten to tighten your handle.
Mar 05, 2013 | American Standard Plumbing
Dont know how to tighten my toilet seat...i have the studio 2 piece from american standard
There is a plastic cap that you need to flip open. You can do this by prying the flap at the top of the hinge. Once you pop it open you will need a screw driver to turn the screw that is inside/underneath the hinges. Turn the screw clockwise until it is good and snug. then snap the hinge cap back into place by applying pressure to it.
Sep 14, 2011 | American Standard Home
Base of faucet leaks- cannot remove set screw at handle American Standard Elite kitchen faucet series 4453
if you are having trouble removing the set screw make sure you are using the correct size allen wrench and confirm that it is a allen screw and not a trox screw. After doing this try tighten the screw slightly before loosening it. This should break it loose.
Feb 25, 2011 | American Standard Kitchen Faucet 6310 020...
Home Logo
257 people viewed this question
Top American Standard Home Experts
Mike
john h
Ekse
Are you an American Standard Home Expert? Answer questions, earn points and help others
