See this FIXYA post:
My digiland dl8006 tablet will not leave the select boot mode what do do
Then see this:
digiland tablet reset
This may help you too!
Digiland DL700D Hard Reset
Anthony
SOURCE: My digiland tablet will not charge or turn on
Check the charger with another device or try a known good charger.
SOURCE: My digiland tablet will not turn on or charge
check with the battery.eirher it has loose connection or has expired
SOURCE: My digiland tablet has been stuck on this screen (shown in pic). How do I get it to start normally?
you should open the tablet get battery out then get it back then turn on the tablet again hope it helps
Hello there, I'm Ryan Owen.
To unlock your tablet, I assume it's android OS, to unlock it, you need to shutdown the tablet first after that turn it on and press volume down button together, after that choose wipe.
In case you need to unlock without losing your data, you can visit this link :
How To Unlock Pattern or Password Lock on Android Device With Easy Steps
Thats it. Hope this can help you :)
SOURCE: why will my Digiland tablet Model DL718M not turn on, even when plugged into the charger
Check the cable charger, if is ok plug in your tablet in to laptop computer could be the software issue and has to be ,,reflashed" new software on
