SOURCE: Gearbox problem
Marco, download pdf file from following website, it's the Haynes manual for Nissan Sentra - the bible for Nissan cars when you need solution to problems that no-one can fix: http://pdfdatabase.com/index.php?q=haynes+1996+nissan+sentra+manual
Testimonial: "Thankx Jonathan, I really neede that. Marco"
You can use a long drift punch to knock the old one off. I use a piece of pipe that is the same size as the inner bearing race and drive it back on.
SOURCE: how do i fix propeller shaft center bearing
Most center bearings require that you disassemble the center flex joint, then remove bearing from the shaft which on some requires use of a press or some type of puller.
SOURCE: How to pull bearings on89 subaru 2wd gl off the shaft at gearbox
With a bearing puller tool.
Welcome to FIxYa.com
REMOVAL AND INSTALLATION Remove in the order shown in the figure. Install in the
reverse order of removal. I Image 1. Nut 2. Lock washer 3. Bolt 4. Nut 5. Nut 6. Lock washer 7. Bolt 8. Nut 9. Washer lo. Nut 11. Lock washer 12. Bolt 13. Rear propeller shaft Propeller shaft (4x2) Before removing the propeller shaft, mark the flanges for
correct installation. Propeller shaft (4x4) Before removing the propeller shaft mark on the front, and
rear side flanges for correct installation. (4x2 Model) When the propeller shaft is removed from the extension
housing, immediately install the SST into the extension housing to prevent oil leakage B2200: 490259440 B2600i: 49 5120 440 1m a Propeller shaft 1. Align the marks. And install the rear propeller shaft. Tightening torque: 49-59 N.m (5.0-6.0 m-kg, 36-43 ft-lb) 2. Install the center bearing support assembly. Tightening torque: 36-53 N.m 3.7-5.4 m-kg, 27-39 ft-lb) 3. Align the marks, and install the front propeller shaft. Tightening torque: 49-59 N.m (5.0-6.0 m-kg, 36-43 ft-lb)
Thank you for using FixYa.com
Regards, Lee Davidian
