Question about Ricoh Office Equipment & Supplies
Hi, I have Ricoh mp2001L machine.and problem is blank page coming when i check toner bottle not rotating. whats solution??
Posted by Maroof Burhanpuri on
OfficeServiceAjnc
  • Ricoh Expert
  • 215 Answers
If toner bottle not rotation then the toner bottle motor is faulty. You can check does the motor work in service mode. But also it might be and the gears on the PCU to be worn out. If you need instructions how to check in service mode does the toner bottle work, please write a comment.
Posted on Jun 26, 2018
  • Ramu Sankri Nov 10, 2020
    I have recoh mp2001l photocopier. It was the problem that the toner bottle not rotate how to check in service mode does the toner bottle work.please explain.
5 Related Answers
Anonymous
  • 62 Answers
SOURCE: Used Toner Bottle Full Ricoh Aficio 1035P
The used toner bottle is not actually a bottle at all. Not sure what you emptied, but it sounds like the actual toner bottle itself. The waste toner is contained with in the transfer belt unit. When you open the right side cover, this is the unit that is attached to the door. It is a brown belt that provides transfer of the image to the drum and separates the paper from the drum. Remove this unit by locating the release levers on either side of the transfer unit (push both of them towards the machine). After removing, you will need to actually take the belt unit off of the transfer unit. To do this, remove the two tension springs on either side, and then take a small flat bladed scredriver and release the clips that hold it down (you will see when you get started). Once you get it off, you will see the long blade that actually scrapes the toner off the belt. Dump the waste toner out this end. You will need to shake it pretty hard. A better (and cleaner) option is to vaccum it out using the crevace tool on you vac. Just make sure you completely empty it. Now....do everything in reverse.
Hope this helps,
Chad
Posted on Oct 09, 2008
Everett Lin
  • 990 Answers
SOURCE: I need to empty or repalce the used toner bottle
Hello sir; You may open side door, you will find out a retangle plastic box that is the waste toner bottle, on the top of waste toner bottle have a green knob, just slide it to right, you can remved it and dump it out.
Posted on May 18, 2009
Anonymous
  • 15 Answers
SOURCE: waste toner bottle - Ricoh MP W2400
Just an FYI, this can be very messy. If you figure out how to get the thing out (should be near your consumable supplies like toner and image units) place the whole unit into a plastic bag, tie the bag, then shake it out gently. You may have to learn how it opens in order to "open the door". Best to use a vaccum with a heppa type filter as normal vaccum filter is too course for the fine toner partcles. Be ready for toner volcano.
Posted on Jun 09, 2009
Ickoajnc
OfficeServiceAjnc
  • 215 Answers
this is the waste toner bottle
Posted on Jul 16, 2009
Anonymous
SOURCE: Toner Cart chip reset for Ricoh Aficeo sp c400dn
I believe you will need to purchase and install a reset chip. You can find them for the Ricoh C410 here at www.cfriends.com (that links straight tothe ricoh page - but if you need to search, type in "c410" into the search field on their site).
Posted on Sep 28, 2009
Howe do i fix ricoh 2060 code sc342?
there are more possible solutions and cause of this error. First of all the sc code and the sign for no toner are connected. The sc code mean that is there is no toner in the developer hopper. First of all if this code appeared after you replaced the developer, you will need did you connected the two connectors that connect the developer unit with the machine, and also check do the developer unit is properly inserted into the machine. But if this problem ocured before you replaced the developer, than the problem is with the toner holder. Open the front door and check the white hook that pulls out the toner bottle cap when the bottle is home position. This white hook is located on the back of the toner bottle holder. you will notice it when you pull the bottle from 90 degrees angle into home position how it slides on the metal rail located next to the toner bottle holder on the right corner of the machine. If it is broken or out of position than that is the problem. If this part is ok that open the front door and put something like a screwdriver in the upper taster that detects do the front door is closed its located above the red main switch, you will notice a hole with a bronze colored plate inside. The other switch is located on the front right bottom corner next to the third paper tray, you will notice a hole in the olive-brown color plastic. When you will insert something into this two holes the machine will think that the front door is closed and it start the toner loading process. While the machine run, with the door open notice do the toner bottle rotates.If does not rotate than the motor that rotate the bottle is not working. If non of this help than tell me and i will tell you other possible solutions.
2helpful
We have a Ricoh Aficio CL3500N and are getting an error stating: "Used toner is almost full." No manual to refer to. Thank you!!
Hi there, You can just empty the waste toner bottle. here is what you need to do. Here is also a manual for your machine http://support.ricoh.com/bb_v1oi/html/oi/re/model/cl3500/cl3500en.htm Detailed instructions on cleaning the Waste toner bottle on Page 32 of the Maintenance Guide. Instead of replacing just empty it. Just be careful as the toner is toxic so you can also vacuum the toner out of the Waste Toner Bottle.
Regards,
Ricoh CL4000DN. I recharged the magenta toner using the OEM cartridge. I replaced the chip as instructed and all elements snapped together without difficulty. However, now there is a "check toner...
Hi, the chip on those toner bottles stores information about how much toner is left, so once that chip registers an empty toner bottle, it won't work even if you attach it to a new toner bottle. You'll need the chip from a new toner bottle, or one that hasn't registered no toner.
1helpful
It doesnt print the first page and its a minolta cspro 3000 and the error code is c0070
This service code C0070 is a universal code used by Konica Minolta to indicate a toner bottle rotation failure. These machines add toner by rotating the toner bottle that you install in the machine. Most of the time this code is caused by a toner cartridge that has been installed incorrectly or has become dislodged from it's holder. To clear the code open the front door or toner door and remove the toner cartridge/bottle from the machine. Close the toner door and turn the machine off then on to reset the code. Let the machine run. This may take several minutes and will allow the machine to bring the toner bottle receptacle into it's home position. Once the machine stops running completely, then you can re-install the toner cartridge. If the code does not come back you are ready to go. If the code came back after removing the toner but before you re-installed it then you have either a dirty rotation sensor or a bad toner drive motor and will need service.
If the code comes back after the cartridge is re-installed then there is either a priblem with the cartridge or with the toner bottle drive.
Most of the time though the problem will be resolved by the outlined procedure.
Good Luck and Thank You for using Fixya.
2helpful
2answers
How do I replace the waste toner?
The waste toner bottle is just a bottle that the old unused toner falls into. It is located on the right side of your printer. Open the right side door, and the waste toner bottle (which is wide and flat) is in plain view taking up the bottom half of view. It has a sliding lock on top. Slide the lock to 'unlock' and remove it. Replacing it is easy - just reverse and make sure to lock.
2answers
Ricoh aficio 2035 keeps telling me to add toner
Sounds to me like the 'plunger' from the top of the bottle may have remained in the machine when you removed the other bottle, and is blocking the flow. Remove the toner bottle and check.
Otherwise, are there any other messages showing, such as "close cover", or something similar? If so, these machines did have a problem, that I may be able to advise you further
1helpful
I used the wrong toner in my aficia 200. I bought
When you say you cleaned the toner "entirely out", does that mean you removed the drum (photoconductor unit) also, and cleaned it out until there was no powder left inside? I bet you did....here's what you've done now, you see, the toner in that machine is what is known as "dual component" vs. "mono component" in many other machines. What this means is that the toner is 'carried' by another product called "developer" in that machine. Guess where the developer is contained?.....inside the drum unit. You have cleaned all the developer out, and so there is no carrier for the toner. Now you'll need to replace the entire photoconductor unit, because you can't get the developer alone -and "yes" like toner they are all different. It's turning into a costly experiment. Bye the way. The toner for that machine is cheap - maybe $50 a bottle for the OEM (depends where you are)?, and generic versions tend not to work well in Ricoh. It lasts for about 8000 pages - that's cheap copying if you do the math - but not now.
Ricoh Aficio 1022 Toner Bleeds
I ended up taking out the toner bottle completely and just running copies (with no toner in place) until they came out crisp. This used up the toner that was floating around. I was able to make about 700 copies before I needed to put the toner back in. But a **** of paper is still much cheaper than getting a service tech.
2answers
Ricoh 1018d won't add toner after installing toner bottle.
the part numbers are different for each toner from ricoh, Lanier, Savin and Gestetner. From what I recall is the bottles are different, check the old bottle vs new. Also if the machine had run very low you may have to open and close the fron cover several times, this intiates a toner feed program.
www.p4photel.com
http://www.websitetoolbox.com/tool/mb/copierquestions
2answers
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
Bernard D'Souza
Timothy Van Der...
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
