Question about Healthometer Health & Beauty
My healthometer digital bathroom scale got wet and it won't turn on., i replaced the battery and it still won't work, the digital screen has not activity
Posted by Linda Canez on
James Basile
    Habit-Forming:
    New Friend:
  • 74 Answers
Place the scale in a dry environment for a few days. Forced air from a fan may assist drying if the pc board did not short out. If it did short out, the pc board would have to be replaced,if possible,otherwise the scale may not be repairable.
Posted on Apr 16, 2018
4 Related Answers
Anonymous
  • 74 Answers
SOURCE: taylor digital bathroom scale
This link allows you to trouble shoot directly with the company... I hope this helps. http://www.taylorusa.com/advantage/root/contact.html
Posted on Jan 07, 2009
Anonymous
SOURCE: Reset digital bathroom scales
I cannot reset my digital scale to lbs. it is a conair ww body mass scale
Posted on Oct 18, 2009
Anonymous
SOURCE: scale does not work anymore. Batteries are still good
and same again. batteries are fine but i get an error message
pete scarborough qld
Posted on Nov 13, 2009
Anonymous
SOURCE: Healthometer Bathroom Scale
http://www.healthometer.com/Manuals.aspx
Posted on Aug 23, 2010
1helpful
Propert bathroom scales does not work after changing battery. keep getting Err message
Check that the battery is in the correct way. Reset the machine after you check battery.
Just replaced battery - trying to reset the scale to 0.0
PDF]Instructions for use of Thinner® Bathroom Scales
www.conairscales.com/catalog.php?product_id=428&ib=en
Scales for the way you live® ... Tap on the scale and wait until "0.0" appears; press Set button, ... button to change the goal weight if necessary, once the ... NOTE: 1. When the scale traps zero error, "Err" will show. Please try again. 2.
How to Set a Digital Health O Meter Scale to 0.0 - Livestrong ...
www.livestrong.com > Weight Management
Aug 12, 2015 - The scale may not register at 0.0 when starting out... ... The Differences Between Balance Beam Scales & Electronic Scales ... 10 High-Tech Health Tools toTry This Year; Are You in Need of a Digital Detox? How to Start Doing Parkour. References. Healthometer.com: FAQs; "Health o meter User Manual" .
SCALE READS 20 LBS TO HEAVY HOW DO I CALEBRATE
Sounds like reset access points. Try pressing something in the hole gently to see if you can hear it clicking a switch...if it does the hold the button in and turn th scales on or turn the scales on and the press the reset. Good luck
1helpful
Does not turn off automatically
Turn remote "off", press and hold "Kg - Lbs" button, turn unit "On". Display should show "0", then "320" or model number. Unit was programmed to disable auto off. Works great now.
Thanks
2answers
Scale does not work anymore. Batteries are still good
Health & Beauty Logo
Top Healthometer Health & Beauty Experts
Tom Chichester
Are you a Healthometer Health and Beauty Expert? Answer questions, earn points and help others
