Microwave Ovens Logo
Andre Lotter Posted on Apr 15, 2018
Anything I can do to fix an Error Code 02 on my LG Lightwave Convection Oven - Model MJ3881BC? Many thanks, Andre Lotter
5 Related Answers
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Apr 20, 2008
SOURCE: My LG Combi Microwave oven
This is usually caused by either a bad door switch (usually the top one), a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Jun 08, 2008
SOURCE: kitchenaid double convection microwave /
I'm guessing the model number would be KEMS308GSS0.
In some cases, this is a glitch that can be cured by unplugging it for 1 minutes, then resetting the clock.
In other case, it may be a bad keypad (membrane switch) or control board.
Please feel free to contact me directly if you need more help.
[email protected]
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Nov 27, 2008
SOURCE: F3 error code GE 120 Adventium
F3 means you have a shorted switch on the key assembly circuit board.
We regularly repair these control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
Feel free to contact me
directly (and please remind me of your model number) for more information & help.
William E. Miller
[email protected]
Anonymous
  • 43501 Answers
  • Posted on Sep 30, 2010
SOURCE: Microwave not heating anything? everything else work
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
fgshg
Anonymous
  • 43501 Answers
  • Posted on Feb 25, 2011
SOURCE: My LG MICROWAVE OVEN IS MODEL
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Samsung SE error code
Followed Timm Eckenroth's suggestions in a post from 08/02/2012
and it fixed the problem on my Samsung same model as his.I was a little skeptical at first ,followed all his steps ,put it back together ,prayed about it and it worked..Thanks to Timm and the ourLord..
Get F3 warning on panel. where are the codes located so i can see what the problem is, thank you JOHN BOMSA
Error code F3 on many models of microwave oven means a problem with the touch panel, (tact switches).
Replace the switch panel to fix the fault.
Hope this helps.
heatman101
fgshg
Error Code F1
F 11 code. it is a touch pad error.
If you just cleaned the control panel it may have water in the panel causing a key to stick.
If after a day or 2 it hasn't dried out - then you will need to replace the touch pad.
Visit www.searspartsdirect.com and enter in your full model number for a parts breakdown and schematics.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
1helpful
Trouble code F1
F1 This code usually means that there is a problem with the keypanel. Many times, it means the keypanel needs to be replaced.
Good Luck
Please rate FixYa!
Instruction manual for LG microwave convection oven
You can download Samsung over the range microwave installation instructions here. If that's no good, try here.
Otherwise, visit this page, click on click on the left-side arrow "Busque por Codigo del Modelo" in the big purple rectangle, enter your model number in the box, then click "Buscar". They may list an English version manual available for download.
Good luck.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Top LG Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
