Question about Pentax Cameras
Cannot locate self timer on pentax k10d - Pentax Cameras
Posted by Joe Vasko on
5 Related Answers
Anonymous
  • 56 Answers
SOURCE: Pentax K10D won't work with lens from Pentax K100 (film0
The lenses are probably manual focus lenses,
  1. Make sure that the apature ring is set to 'A' or automatic,
  2. if these are manual focus lenses then switch the focus switch on the left side of the camera body to MF
  3. If this still doesn't work, or you are having trouble with the apature ring then press the menu button to go to the  menu then press the right arrow key untill you are in the  Custom Settings, scroll through the custom settings with the up and down arrow keys until about the 2nd from bottom there is an option called "using aperture ring" set this to 2 (Permitted) This will make the camera take a image when lens is on any f-stop manually.
Try this and everything should work fine. If all this hasn't worked then try seting the mode dial on the camera to M manual mode. Cheers
Posted on Sep 10, 2008
Gort007
Just Gort
  • 1187 Answers
SOURCE: can I use sunpak 1600a flash (older) with Pentax
Yes, it's possible.
The flash sensor is calibrated for a 35mm optics & iso (asa).
You may have to "UP" your digital camera's iso sensitivity to 800 or so.
You will have to experiment with it at various settings.
Try using the "bracket" sewtting on the camera.
It takes three pictures when you press the shutter button; the three have different "values" of brightness.
The bracket setting is on the UP arrow, where you can choose "single frame", "continuous frame", bracket, etc.
Hope this helps!
Posted on Sep 14, 2009
Ty Price
  • 11967 Answers
SOURCE: slow to autofocus and sometimes will not focus at
Clean the contacts on the camera body and the lens where they connect with a cotton swab lightly dampened with rubbing alcohol.
Posted on Sep 28, 2009
Johny
  • 540 Answers
SOURCE: Pentax K10D shake reduction switch broken
Repairing the camera is little bit tough for a end user but it can be repaired in any service center as it is a Pentax k10D I will recommend you to keep this camera because this days getting a Japan made camera is as tough as getting water in desert.
Posted on Feb 19, 2010
Anonymous
  • 10 Answers
SOURCE: My Pentax k10d don´t power on. Please some
click and hold on the power botton.
Posted on May 12, 2010
I switched of my pentax k10d during firmware update by mistake now it wont power on
That's the biggest "no-no" in the digital camera world. You need to e-mail the techs at the support section of the Pentax website for specific directions about what to do next. There's also a link for a "live chat" if you prefer that method.
Oct 19, 2011 | Pentax K10D Body Only Digital Camera
I have a Pentax K10D from the time they were first sold. I have not installed any firmware as not very technically talented. Have recently bought a Sigma 120-400 zoom.( no zooms of this range from...
Only Pentax DA and FA J lenses and D FA/FA/F/A lenses having an "A" position on the aperture ring can be used with this camera.
The lens you have is HSM DG
Jun 10, 2017 | Pentax Cameras
I have a Pentax K10D Im getting an error message on my camera "Card reader error" I have changed memory cards to no avail.
Hi, It seems that your memory card slot has been malfunctioning, So get it serviced...
Thanks
Jun 23, 2010 | Pentax K10D Digital Camera
Feb 19, 2010 | Pentax K10D Digital Camera
Slow to autofocus and sometimes will not focus at all with my pentax k10d slr digital camera with a pentax 16-50 da lens. when I switch to manual focus the camera works fine.
Sep 27, 2009 | Pentax K10D Digital Camera
Feb 12, 2008 | Pentax K10D Body Only Digital Camera
Cameras Logo
Top Pentax Cameras Experts
halotheracer
halotheracer
Steven Wander
Steven Wander
Mat Kramer
Mat Kramer
Level 1 Expert
Are you a Pentax Camera Expert? Answer questions, earn points and help others
