SOURCE: Nikon MH-53 Lithium Battery Charger - help?
download the manual here
http://www.retrevo.com/s/Nikon-MH-53-review-manual/id/605ag014/t/1-2/
SOURCE: my Nikon Coolpix S8000 will no longer read the
Sounds like you've added images to the card using the computer or another camera. The Nikon doesn't recognize them and concludes the card is empty.
SOURCE: Why doesnt the lens cover
This
is such a common fault that I hope you don't mind me pasting my stock
generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common
reason that compact digital cameras get thrown away, but there's a fair
chance of recovering use of your camera again
The fault is
commonly caused by dirt or grit blocking the mechanism, or due to it
having suffered a recent fall. Another common cause is that the camera
was in a pocket or bag and the power button accidentally activated and
tried to open the lens against resistance. The mechanism may have simply
become
dislodged or there may be parts which have broken.
If your camera
is still under warranty and has definitely not been subject to misuse
then contact the Nikon service department in your country to find out about a free repair. If
the warranty has expired though a professional repair will far exceed
the
cost of replacing your camera. You will therefore have nothing to lose
by
trying to fix this yourself.
Please click here
and you will be taken to an excellent article provided by the Camera
Repair website. For the most part, you'll be guided on how to physically
manipulate your camera to try and clear the fault.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good
luck, I hope you manage to use this information to fix your camera.
Please take a moment to rate the free answer I have provided for you.
SOURCE: my nikon s8000 wont turn
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
SOURCE: I have a nikon coolpix s3200 and it won't charge!
Hi there I was told that jumpear something on the plate to be reset to factory state solutions and hope you tell me if it is true that thanks
