Question about Samsung Office Equipment & Supplies
I need a user guide for Samsung c48 printer to explain about when the toner needs replacing and how to do it
Posted by Perdita Swift on
Terry
  • Samsung Master
  • 11,359 Answers
Dream
  • Samsung Master
  • 6,120 Answers
Restore Deleted Data from Samsung
Here I'll introduce you Android ToolKit - Android data recovery to restore deleted data from Samsung, which has been widely accepted as the best recovery tool to recover deleted data from Samsung Android phone selectively. By using this tool, all deleted contacts, messages, call history, videos, photos, documents, WhatsApp messages, and more will be deeply scanned and recovered from your Android device. You are allowed to preview the data before recovery.
Additionally, this program enables to extract data from broken Android device, backup & restore Android on computer safely. Compatible with almost all Android models, such as, Samsung (Galaxy Note 9/8/5/4, Galaxy S10/S9/S8/S7/S6), HTC, Lenovo, Huawei, Google Pixel, LG, Sony, OPPO, OnePlus, ZTE, Xiaomi, etc,.
LEARN MORE
Android Data Recovery Software How to recover deleted and lost data from Samsung on Mac How to recover deleted and lost data from Samsung Galaxy J1 J2 J3 J5 J7 How to recover deleted and lost Contacts from Samsung Galaxy J1 J2 J3 J5 J7 How to recover deleted and lost SMS from Samsung Galaxy J1 J2 J3 J5 J7
Posted on Jun 17, 2019
5 Related Answers
Mike Waldron
  • 1019 Answers
SOURCE: Samsung ER-220 cash register till user guide
This model is obsolete.
The nearest you,ll find is Here:-
http://www.tnt-gifts.com/cash-register-manuals/samsung-cash-register-user-manuals.html
Mike @ compurepair.
Posted on Mar 15, 2008
Anonymous
SOURCE: Samsung sf-5100 fax toner empty
I have a feeling that it is a re-manufactured or compatible cartridge??
There is a fuse that needs to be replaced on this unit. it blows when the cartridge is installed to reset the machine. If the fuse has not been replaced or is defective the machine will not recognize the new unit.
Posted on Mar 07, 2009
Anonymous
  • 190 Answers
SOURCE: Need user guide
Dear customer,              You can get the free copy of manual from the following link http://www.retrevo.com/support/Samsung-SCX-5530FN-Multifunction-Printers-manual/id/260dj297/t/2/ click on the "get manual" red box. Thank you. Please rate solution.
Posted on May 12, 2009
Yuk-Wa Chan
  • 133 Answers
SOURCE: Toner cartridge needs replacing in brother hl-20
if you want to replace your toner,
First you just need to open your front cover and pull out the toner and drum.
after that, push down the blue buttom on drum and pull out the toner. Then replace the new toner into the drum.
finally, just push back the drum and toner back into the printer.
Posted on May 23, 2009
Anonymous
  • 392 Answers
SOURCE: toner replace error
if you've refilled the cartridge,you'll have to reset the toner count also to zero...to do this,download the firmware here http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=in&CttFileID=2238869&CDCttType=FM&ModelType=N&ModelName=ML-1640&VPath=FM/200904/20090416100856890/ML-1640_V1.01.00.83.exe
run it and it will reset your toner count to 0...you have to do this everytime you refill your toner.
The firmware for 4300 is not available on the Samsung site,you'll need to google for it.
Posted on Sep 01, 2009
Scx-6345n toner supply error
DID YOU RESET THE PRINTER TONER ERROR? CHECK YOUR USER GUIDE.
Feb 15, 2012 | Samsung SCX-6345N Printer
Two months back, I bought Samsung SCX-4300 printers. Uptil now, it yielded only about 800 prints and now started giving indication that "toner is low". Should I go to replace the introductory toner with a...
The problem is that Samsung wants you to buy a new cartridge every time you get "toner low" or "toner exhausted"message but..there is a solution :
You have to flash the printer with a fixed firmware so that you can just refill the toner cartridge and continue printing :) The procedure will take about 5-6 minutes if I am do it personally ( for this to happened i need you to press a combination of buttons on the printer to get into TECH MODE and then I need access to your computer and printer CONNECTED to it so I can upload the new firmware to the printer - this is because if i have to explain to you the whole procedure it is going to take me a far more time than i have to spend on this. If you want me to help you i will give you a details how we can do this exactly...if not...go buy a new toner cartridge :)
May 23, 2010 | Samsung SCX-4300 Monochrome Laser...
When should I replace the toner cartridge? I found that red light is flashing( the lower light, totally there are 2 lights: upper one is green now). I don't understand what does it mean.
It mean when your toner is near empty,then red light flashing.tow light is fixed or red mean toner cartridge is empty.must be replace toner cartridge.You buy a new cartridge and put in your printer then printer is OK.
you can also get better idea please read printer user guide.
Mar 04, 2010 | Samsung ML-2240 Laser Printer
How do i add toner to my hl 2030 brother printer ?
You don't "add" toner, you have to replace the cartridge. You can see it by clicking on this link:
HL-2030 Toner
You can refer to the User Guide for instructions. here is a link to it:
HL-2000 Series User Guide
Replacing the toner is covered in Chapter 5.
Thanks for using Fixya.
Jan 09, 2010 | Brother HL-2030 Laser Printer
Instruction for changing toner on Magicolor 2430
This owners manual for your device should explain how to replace this part:
http://safemanuals.com/user-guide-instructions-owner-manual/KONICA%20MINOLTA/MAGICOLOR%202430%20DL-_E
May 22, 2009 | Konica Minolta magicolor 2430 DL Laser...
Hiw do I reset the
The following conditions can cause the On Line LED to glow:
* Printer paper is jammed inside your printer.
* A cover is not be closed properly.
* The toner cartridge is not inserted properly and needs to be reinstalled.
* The toner cartridge is running low.
* There is no paper in the paper tray.
* The paper inside the paper tray is not be installed correctly.
Red Error Light Blinks
If your printer's On Line LED is blinking red, your printer's toner is exhausted and needs to be replaced. For replacement cartridges, please click here to visit our official online parts distributor.
On Line and Error Light Blink Simultaneously
If your printer's On Line and Toner Save LEDs blink simultaneously, your printer requires service
Apr 14, 2009 | Samsung ML-1640 Monochrome Laser Printer
Apr 01, 2009 | Brother HL-2040 Laser Printer
Replace toner
Please click here and the installation guide to install the toner cartridges ..
Good luck..
Nov 11, 2008 | Lexmark C912 Led Printer
Reset C48 printer
i need to reset my c48 anybody help?
Feb 12, 2008 | Epson Stylus C48 InkJet Printer
76 people viewed this question
Top Samsung Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Muntejaya Ginting
Muntejaya Ginting
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
