Question about Kohler Home
Kohler dtv main shower head shuts off after a minute or two. Body sprays and rain showers stay on but we only want to use main shower head
Posted by Lisa Barbarine on
5 Related Answers
Anonymous
  • 68 Answers
SOURCE: Pressure problem with Kohler shower faucet??
Hi pglaw,
My best guess is the supply valve for the hot side isn't open all the way. This valve is right on the valve and is accessed by taking off the front cover plate. This would still allow the pressure balancing valve to let water through but then you would have a small flow on the hot side.
If this isn't it then then cartridge is bad.
Please rate this response and good Luck,, phil
Posted on Dec 31, 2008
Anonymous
  • 35 Answers
SOURCE: dripping shower head
If it is dripping from the connection where it goes to the water spout you can unscrew the connection and wrap teflon tape or Pipe Joint Compound on the Threads. Now you can Thread the Shower Head Back on, with No Leak. IF..... It is leaking from the Shower Head Itself There May Be a Problem with the diverter handle/lever. If it has a Pull Type Lever, sometimes you can screw the Lever up or down for the proper water restriction to the Shower Head. However if the Hot and Cold Handle/Lever is OFF, There should not be any Water coming out from anywhere! If water is coming out off the Tub Spout, with the Shower Off, then you will have to replace some washers or Cartridges in the faucet(s) to stop the dripping. You can do this easily....Just Ask) Remember though, that some shower Heads may Drip for a Few Minutes After they are Turned off. There is still water in the Supply neck and needs to escape, either though the tub Spout or Shower Head.......Hope this Solution Helps you with your Drips.....Joe
Posted on Feb 01, 2009
Anonymous
  • 195 Answers
SOURCE: kohler bath/shower diverter stem stuck on shower
Probably has water deposit minerals build up on it. Push and or pull with pliers until freely moves,soak in Lime away solvent ,toothbrush on.
Posted on Mar 16, 2009
Bruce Hathcock
  • 3600 Answers
SOURCE: Kohler Fairfax shower faucet repair
You will need to buy the o-rings to fix it. You can buy at most hardware stores if you know how to turn off the water you can fix this with more instructions. Let me know if you need more help.
Posted on Sep 27, 2009
Anonymous
  • 21 Answers
SOURCE: leak where Grohe shower head attached to the threaded pipe
using a pair of vice grips wrapped in a soft towel( to prevent scractching) turn the shower head in a counter clockwise direction to remove it then apply liquid teflon (real-tuf) to the threads on the shower arm and tighten the shower head but dont over tighten it liquid teflon is more effective at sealing leaks than teflon tape and it can be wiped clean
Posted on Dec 03, 2009
This shower has 3 body spray jets. The lower jet does not work. I need to remove the lower one to see if there is debris in the line, blocking it. It is a Kohler k 8002 cp body jet. How do I disassemble it...
There are some clips on the top of the spray head that fasten it into place. I found this pic that may help and your Kohler owner's manual should also have more info.
Mar 19, 2015 | Kohler Electrical Supplies
Low water pressure from my shower.
You probably have a water flow reducer in the shower head. It is a rubber disk with a few holes in it. Just remove it and put the shower head back on. They are installed at the factory to save our environment. (Mine are all removed)
Dec 05, 2012 | Kohler Home
I need troubleshooting help with my three function transfer shower valve .
valve is bleeding by remove and check the condition of cartrige look for wear or dirt
Apr 28, 2012 | Home
One shower head inn 3head automatic system does not spray, just drips.
there could be dirt in the shower head or the two way divertor valve. i would remove the shower head first.
Dec 29, 2010 | Kohler Plumbing
How do you adjust the hot water on a shower deverter
Diverter valves don't regulate the temp at all they are used with a standard shower valve that regulates the temp and the diverter selects the shower head/body spray/Rain head or whatever configuration you have. This valve can't be used on it's own.
May 25, 2010 | Delta Plumbing
Shower body three way diverter problem, no water to one port
try taking the shower head off and see if there is something stuck in it. sometimes things will come through the water lines and lodge themselves in the valves as well. if the shower head isn't clogged try dismantling the valve that turns the shower head on and then turn the water on when its out and flush the port out.
Jun 11, 2009 | Hansgrohe Axor Hansgrohe Starck Shower...
Shower head angle
TRY TIGHTENING THE HEAD.
IF IT DOSENT WORK U MAY BE MISSING THE RUBBER O-RING THAT SEATS BEHNID THE BALL.
May 05, 2009 | Dishwashers
My Hans Grohe rain shower head is having a lighter spray recently. Is there a way to improve the spray force and/or clean it? Thanks, Therese Terschuren
Rain head showers are a nice thought, but they come with a bundle of problems. This is common one, though, so fear not.
As long as your regular shower head isn't losing pressure (I'm assuming that you have at least two heads instead of just one rain head) I would recommend carefully removing the head with an adjustable wrench and letting it soak in CLR (calcium lime rust) for at least an hour. Often times minerals in water will build up in the small holes on a shower head and greatly reduce efficiency.
Remember to apply teflon tape to the threads before carefully retightening the shower head to avoid spraying water from the wrong end!
Mar 25, 2009 | Home
Kohler K-9511-BN MasterShower Shower Arm & Diverter Doesn't Work
As a helpful hint , on these models, When installed some plumbers or home owners use plumbers putty to seal the threads and in some cases tape.
Most of the time the putty or tape gets pushed through the system if too much was used.
Check by removing the shower head and testing the pressure and blowing anything else through, then checking the head itself for foreign objects.
Kohler has a cleaning and care page on thier web site if it needs cleaned.
Jan 10, 2009 | Kohler K-9511-BN MasterShower Shower Arm &...
Home Logo
156 people viewed this question
Top Kohler Home Experts
john h
Bill Johnson
Mike
Are you a Kohler Home Expert? Answer questions, earn points and help others
