Question about Kenmore Kitchen Ranges
SOURCE: Admiral electric range with self cleaning oven
There is an automatic lock feature on this unit that after 1 hour will unlock itself.
hope that helps!
Posted on Jan 30, 2008
SOURCE: Kenmore double oven flashing locked door, door not locked, oven wont respond
hey i have the same problem, i moved into this house so i have no manuel. this is crazy, i hate this oven. i would personally never buy this oven. if you guys have figured out this problem i would really appreciate a response. thanks Justine Canada
Posted on Feb 18, 2008
SOURCE: frigidaire oven door locked
SOME RANGES ARE DESIGNED TO LOCK IF THE CONTROL SENSES A TEMPERATURE EXTREME. IF THERE IS A FAILURE OF THE SENSOR THAT MAKES THE CONTROL THINK THE TEMP IS UP, IT WILL LOCK THE DOOR TO PREVENT INJURY. REMOVE THE BACK PANEL AND FIND THE OVEN SENSOR LEADS COMING OUT THE BACK OF THE OVEN. DISCONNECT THE SENSOR AND CHECK THE RESISTANCE. AT ROOM TEMP IT SHOULD BE SOMEWHERE AROUND 1084 OHMS. IF IT IS NOT CLOSE,
THE SENSOR IS BAD. PLUG IN A NEW SENSOR AT THAT CONNECTOR AND THE DOOR SHOULD UNLOCK. THEN GET INSIDE THE OVEN, REMOVE THE OLD SENSOR, AND REPLACE IT WITH THE ONE PLUGGED IN.
Posted on Apr 04, 2008
SOURCE: Older Kenmore oven- door locked by itself
We had a quick power outage and when the power came back on it locked our older (1991) Kenmore electric oven model # 40889 / 40881. Went throought the manuel and nothing pertains to this problem. We have turned off the circuit breaker and turned back on, but nothing seems to unlock the door. Any suggestions would be GREAT!!!!!!!
Posted on Mar 16, 2009
SOURCE: Kenmore 790 Oven Locking mechanism problem
hold down the stop/clear button for 3+ seconds
Posted on May 25, 2009
Oct 03, 2018 | Kenmore Cooktops
Mar 11, 2010 | Kenmore 99123 Electric Kitchen Range
Feb 03, 2010 | Kitchen Ranges
Jul 11, 2009 | Kenmore 9446 Range
Jan 13, 2009 | Kitchen Ranges
Dec 31, 2008 | Kenmore 96212 / 96214 / 96219 Electric...
Dec 29, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Jul 14, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Mar 03, 2008 | Kenmore 94220 / 94221 / 94222 / 94224 /...
Oct 24, 2006 | Kenmore 40494 / 40495 / 40499 Electric...
66 people viewed this question
