Question about Kenmore Dryers
SOURCE: Dryer not heating
what is the model #the heater is not in the back of the he4.
Posted on Nov 05, 2008
SOURCE: heating element for kenmore dryer won't turn on
Hi, I have an 11yr old 80 series elec. dryer and just fixed the same problem. On the heater element is a thermostat with 2 wires and above that about 14" is another piece with 2 wires. I had to replace the top one. They sell them together in a kit called Thermal cut off kit. Sears sell it for 25.49 look up part number 279816 or 3399848 again these numbers are for my dryer but you can look them up on the sears parts web site. If you have a sears service center near by they let me buy the parts to see which one it was and then return the ones I didn't need. I hope this helps.Good luck
Posted on Jan 06, 2009
SOURCE: Replaceing a heating element, Kenmore Elite 90 series dryer
u remove the front
Posted on Dec 04, 2009
SOURCE: dryer won't heat
The back panel doesn't come off for service!!! Most heating and control components are available behind the kick panel below the main dryer door..
With electric dryers my normal train of thought in diagnostics is to start with source of power. Do I have 220 volts available at the terminal board where the electric cord is connected??? Quite often I find a blown fuse, etc to cause it to stop heating as the motor will run fine on 120 volts as thats all it requires, but the unit will not heat with out 220 volts to the element..
best of luck, and have fun,
ttfn
Posted on Feb 02, 2010
SOURCE: My Kenmore elite electric dryer will not heat. I
Hi
Thanks
for using FixYa. No Heat
issue in an electric dryer is usually caused due to three things mainly:
Thermal Fuse, Wiring Harness and/or Heating Element. Start with checking the
Thermal Fuse which is mounted inside the back cover panel to the exhaust duct
and is mounted in white plastic housing. If that’s fine then the Heating
Element should be checked. Please do rate the solution if the
issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 03, 2010
Feb 12, 2014 | Kenmore Dryers
on Mar 20, 2010 | Dryers
Jun 21, 2011 | Kenmore 63942 Dryer
Mar 12, 2010 | Kenmore 62992 Electric Dryer
Feb 28, 2010 | Kenmore Elite HE4 Electric Dryer
Nov 12, 2009 | Kenmore Elite HE4 Electric Dryer
Oct 09, 2009 | Kenmore Dryers
Apr 12, 2009 | Kenmore 63032 Electric Dryer
Nov 30, 2008 | Kenmore Elite 45986 Front Load Washer
Jul 12, 2008 | Kenmore Elite HE4 Electric Dryer
Jan 20, 2021 | Kenmore Dryers
133 people viewed this question
