Question about Staples Office Equipment & Supplies
I recently bought a Staples Shredder Model #SPL-TXC152A & has worked fine up until now. I emptied the bin as I have previously & bow shredder will not turn on.
Posted by Annemarie... on
Tom Chichester
    Top Expert:
  • Staples Master
  • 56,001 Answers
There is a bin interlock switch that has to be closed for the shredder to shred. If the shredder mechanism is separate, look for a slot on the underside.
Posted on Apr 13, 2018
5 Related Answers
Anonymous
SOURCE: Staples SPL-1506X Shredder Issue
I had the same problem. I have a solution but I do not recommend this unless you have technical experience with repairing electrical appliances. I took the back cover of the main shredder unit to expose the wiring (there are 7 screws in total). The bin full sensor has a blue, green, and red connected to it. I clipped the blue wire to defeat the Bin Full error. You can look through the plastic window to check that the bin is full.
Posted on Aug 09, 2008
goalie39
Ed
  • 479 Answers
SOURCE: what is the interlock for a staples shredder
if you look at the underside of the shredder, you will likely find a pressure switch that is actuated when it sits on the stock bin, either modify it to touch when on the new bin or secure it so it is depressed all the time. This should allow it to operate on the replacement bin.
Hope this is of some help.
Ed
Posted on Apr 20, 2009
FixinFax
Leroy Elliott
  • 3085 Answers
SOURCE: I need help in trouble shooting my staples
Therer should be a tab hanging down that senses when the paper height trips it.
Blow into the sensor with canned air.
Posted on Oct 13, 2009
Anonymous
SOURCE: staples spl-710sh paper shredder stopped shredding
This exact thing has happened to my unit as well. Ive disassembled it to discover that 5-7 teeth on the gear that the motor drives have been stripped off. Unless the gear can be replaced (which is probably not worth the expense), then the unit is toast. Sorry. Good luck.
Posted on Nov 01, 2009
Anonymous
SOURCE: Runs continuous when turned on, but stops when paper is inserted
I owe this to a Steve-EE.
Mine was the LED where the paper feeds. $1.69 for a 2 pack.
http://www.radioshack.com/product/index.jsp?productId=3107633
Posted on Jul 04, 2010
I'm looking for a manual for an spl tmc162a staples shredder
The bin has not been inserted sufficiently to close the interlock switch.
Feb 04, 2018 | Staples Office Equipment & Supplies
Staples SPL-QW120D shredder is stuck on "Bin Full" even when empty?
Check operation of the bin interlock inside the area where the bin fits. It may be damaged/defective.
Sep 16, 2016 | Staples Office Equipment & Supplies
Staple Model SPL-XC200D Paper Shredder, During the
Fixya does not sell parts and cannot identify sources.
Jul 18, 2017 | Staples SPLXC200D Shredder
What is the interlock for a staples shredder
Ed
Apr 20, 2009 | Office Equipment & Supplies
Apr 25, 2008 | Office Depot Ativa DQ60M Shredder
651 people viewed this question
Top Staples Office Equipment & Supplies Experts
gbob59
Marvin
Marvin
Vernon Taylor
Are you a Staples Office Equipment and Supply Expert? Answer questions, earn points and help others
