Question about Woods Freezers
Woods upright freezer is working but want freez the contents even removing the ice built up at the bottom of the freezer in a small hole.
Posted by madat virji on
5 Related Answers
docjohn174
john gagnon
  • 943 Answers
SOURCE: Water does not drain from the Freezer during the defrost cycle
hi thanks for the question the drain hose goes to the underneath by the compressor thaw out the freezer and clean the drain hose this will solve the problem thanks the appliance doc
Posted on Sep 27, 2008
Ronnie Houston
  • 2920 Answers
SOURCE: Ice forming on pipes in back of freezer
you could have a freon leak allowing the pipes to freeze up
Posted on Dec 31, 2008
Anonymous
  • 700 Answers
SOURCE: Ice forms on copper pipe under freezer off compressor
it sound like your unit has a bad sensor on it or a leak. you should never have to add refrigerant to a unit unless theres a leak then it has to be repaired firdt the recharged.
Posted on Jan 11, 2009
cactus bob
BOB BROWER
  • 267 Answers
SOURCE: Kenmore Upright freezer needs cleaning under bottom shelf
most of the sears freezers . lift up on the shelf that will unlock it then slide it left or right ( it may move a little hard ) that will unlock the other side , lift and remove ( one side at a time ) ... you will see its not that hard , its just hard to put it in words .....Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob
Posted on Mar 04, 2009
Anonymous
  • 400 Answers
SOURCE: ICE BUILDUP ON BOTTOM OF FREEZER, DRAIN HOLE FROZEN
There is normally a small filiament of metal which is attached to the defrost element and conducts heat down the drainpipe preventing ice build up. You can pour some boiling water onto this area and even wriggle a piece of plastic tubing down the drain pipe to dislodge any blockage. For future prevention, you can attach a piece of copper wire around the defrost element (in the absence of the original filiament) and extend it down the drainpiple
Posted on Mar 05, 2009
Wood freezer f17wce bottom ice
There is water accumulation at the bottom under the basket it forms a thick piece of Ice that we have to break in order to remove it every second day what can I do ..
Feb 24, 2014 | Woods Upright Freezer MU07W
I have a 17 cu ft. frost free freezer, Model F17WCE and I believe the tube is clogged. I thought if I found the plastic tube, I would wash it out. I saw the tube from the front of freezer, while lying on...
Usually you can access a service panel to where the fan and evaporation department is.
I don't know about a wood but I did work on an upright not long a go and took some pics.
See the drain hole below the fan on the floor there?
Thats what ya gotta clear. I use a shop vac myself but I let the freezer thaw all the way out , you could use a hair dryer to melt the ice.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 13, 2011 | Woods Upright Freezer V1613RW3
Why is water is gathering and freezing at the front on the bottom shelf of the freezer?
because your drain hole is stopped up clean all of the ice from the area and flush with hot water
Nov 18, 2010 | Woods Upright Freezer V1613RW3
Ice accumilation at bottom of upright freezer
i could be wrong, but, look along the bottom of the door to see if the seal is tight to the frame......if there is an air gap it is causing the floor to freeze the cold air....
Jun 04, 2010 | Woods Upright Freezer MU07W
I am getting ice around the door and the bottom of the freezer
This is usually due to a plugged up drain. If you look behind the food and shelves near the bottom you will see a small hole facing down. This can be flushed with hot water using a turkey baster until the water runs free
Apr 16, 2010 | Woods 201 cu. ft. Upright Freezer V2003RW3
Ice collects on the bottom of my frost free woods freezer
im not sure if i answered this one before. but this sounds like a blocked drain, the drain is located midway behind the shelves, you can take away the catch tray and poke a coat hanger down this hole hole to dislodge the blockage.
Nov 10, 2009 | Woods 201 cu. ft. Upright Freezer V2003RW3
My upright freezer has a small amount of water inside that freezes, creating an ice slide in bottom.
look at the bottom of your freezer, you will find a small hole or opening, it is a drain exit point of your defrosted water, try to clean it, maybe there is a small object bocking up the way or the hose all away down
Nov 06, 2009 | Whirlpool 19.6 cu. ft. / 555 liter Upright...
Sears Freezer, Model 253 9284013-unable to locate manual, nor online. Freezer did not maintain freezing level, fish thawed slightly, dripping liquid onto bottom interior. It froze over. On bottom, at the...
Your problem could be caused by a clogged drainage tube. even though you may have removed the ice it may still have a clog. my suggestion would be to take all of the contents out of your fridge and let it sit unplugged for atleast 24-48 hours with the doors open this will eliminate any left over ice that may be clogging your drain tube. if this dosent help then you may have a defrost heater problem, or possibly a defrost termination switch problem. as for the smell i know that vinegar works well for getting rid of odor. ther eis also a product you can purchase called fridge aid, it is a charcoal based air purifier and should work well.
Oct 11, 2009 | Kenmore Freezers
Mar 05, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Freezers Logo
394 people viewed this question
Top Woods Freezers Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Woods Freezer Expert? Answer questions, earn points and help others
