Question about Woods Freezers
Woods upright freezer is working but will not freez the contents
Posted by madat virji on
5 Related Answers
JEFF SIEGEL
  • 311 Answers
SOURCE: Kenmore Upright Freezer
Control is bad and needs to be replaced. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Posted on Nov 28, 2008
william whittaker
  • 10 Answers
SOURCE: My woods upright freezer keeps
check your door seal, by closing the door on a strip of newspaper all round the seal. this fault is usually air getting inside the freezer, it rises to the top making thick ice or snow.
Posted on Feb 07, 2009
kachbibi1
Bill Dickerson
  • 979 Answers
SOURCE: problem with upright freezer not freezing
It sounds like the unit is low on freon or the compressor is going bad. You have several other components that could be affecting this as well. Make sure the coils are free from dust and clean underneath. This is a bit premature for you to have problems now, especially since it is a Sears product.
Posted on Feb 17, 2009
Earnest Bowes
  • 234 Answers
SOURCE: woods upright freezer
I would look at the defrost control [sometimes they are defrost clocks]Maybe that the freezer is not defrosting.
Posted on Jun 26, 2009
geoff hunter
  • 4793 Answers
SOURCE: HOW TO DEFROST WOODS UPRIGHT FREEZER
just switch it off at the mains.DO NOT USE SCRAPERS OR STEAM.....(you can use car de icer but you will need to make sure its well ventilated)best left for 24hours....
Posted on Oct 03, 2010
My Woods upright freezer MU07W running great for 9 years. Will it continue to run if I decide to place it outside on the balcony where temperature goes down to 20 below F or to max of 90 F plus?
Not the best idea. We had one in our garage where it got cold but not that awful cold. Not a good idea unless you want to take a chance.If the unit shuts down for a long time because of the cold the system could freeze or seize up.
Feb 05, 2017 | Woods Upright Freezer MU07W
I have a woods upright freezer that freezes up on the ledge below the fin area?
The drain line is clogged, clear the drain with hot water ONLY and it should fix the problem
Mar 14, 2015 | Woods Freezers
Drain keeps freezing
The problem may be the freezer drain heater has failed, locate the drain inside of the freezer compartment and check to see if it is warm, if not you may need to replace the heater.
Jun 30, 2010 | Woods Upright Freezer MU07W
The freezer is not freezing evenly. Only the bottom is freezing. I think the fan is not work. Is there anything else that could be wrong. It is an upright freezer. I took the inside cover off and the fan...
Yes, the fan needs to be running. I can't say for sure since I can't test it, but if you can, test for voltage to the fan wires. If it has voltage, replace the fan.
Jan 03, 2010 | Woods Freezers
Ice collects on the bottom of my frost free woods freezer
im not sure if i answered this one before. but this sounds like a blocked drain, the drain is located midway behind the shelves, you can take away the catch tray and poke a coat hanger down this hole hole to dislodge the blockage.
Nov 10, 2009 | Woods 201 cu. ft. Upright Freezer V2003RW3
Water in bottom of freezer
the drain needs to be check for any kind of blockage. if the drain is blocked or frozen over this needs to be cleared
Sep 16, 2009 | Woods Upright Freezer MU07W
My woods freezer was working fine i defrosted it and now the motor only runs for a few second and then shuts off help
I have a woods freezer Woods model v15hds . I just got it out of storage yesterday,. I plugged it in and can hear the motor running and the shleves are cool, but it is not freezing. What could it be
Mar 11, 2009 | Woods Upright Freezer MU07W
Freezers Logo
517 people viewed this question
Top Woods Freezers Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Woods Freezer Expert? Answer questions, earn points and help others
