Question about Electrical Supplies
Where do I put oil in goplus 1200 watt generator?
Model GG1200 Engine UP65
5 Related Answers
Anonymous
SOURCE: lost manual 6250 watt coleman generator what oil to use and were
If it has the Tecumseh engine..
Above 40°F Straight SAE 30W
Below 40°F down to -20°F Straight SAE 10W or SAE 5W30 or
Below 40°F down to -40° SAE 0W30 Synthetic
Using multigrade oils above 32°F will increase your oil consumption. SAE 10W40 is not recommended.
Per the manual, all the oils should be marked A.P.I. Service SL/SJ, but you may have to use something to a newer standard. E.G.: Service SM.
The oil sump capacity is 1-5/8 U.S. Pints or 0.76 Liters.
Hope this helps.
Posted on Dec 31, 2008
sal_kh_sab
sal sabea
  • 98 Answers
SOURCE: 6500 watt diesil generator /as soon as i put any
if by fliping the breaker it shuts off..that means there is a short circuiting in the breaker..try connecting your house,shop..etc..directly ...
that is if the shut off reason is overloading...if not please explaing with details
Posted on Oct 26, 2009
rwvanlue
Roland W VanLue
  • 486 Answers
SOURCE: I HAVE 6200 WATT GENERATOR AND IT JUST STARTED TO LEAK OIL
It maybe a crankshaft seal.
you will have to remove the genset from the engine.
Normally there is a Thru bolt aprox 12" long that is attached to the crankshaft.
1) remove the genset windings/housing from engine
2) remove the thru bolt
3) with a 2x4 block of wood laying on the metal of the armature (NOT the windings)
4) forcefully wrap with a large hammer, DO NOT hammer on the brushes/comutator bars. Only on the metal housing that has the windings around it.
*the shaft is tapered, and it will take a 'jar' to seperate the crank and the armature.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Posted on Nov 23, 2009
Sheldon Dedek
  • 912 Answers
SOURCE: PF 2500 watt generator... Need plug and oil
30wt oil, probably a Champion RN4C plug. Could give link to a manual if part / model number of generator was provided.
Posted on Jun 12, 2010
Anonymous
  • 80 Answers
SOURCE: Im wondering what kind of oil to put in my 5500
Use a good quality single weight oil 30w
Posted on Oct 19, 2010
What kind of generator oil does it take for a 1200 watts pulsar model no.PG1202S I use a 2-cycle engine oil but it makes oily in the muffler
Use the oil designed to be mixed with your fuel. Available at all outfits that sell generators, etc. Walmart and home depot have it.
Sep 09, 2017 | Watts Electrical Supplies
Starts runs great turn off the it won't start again
Generator runs then shuts off - YouTube
? 8:17
https://www.youtube.com/watch?v=6esHkPyygWw
Sep 6, 2011 - Uploaded by mainblind
How to make Generac generator run bypassing the low oil sensor and ... Great video on low pressure warning switch removal and ...Pulled off the shroud over the sensor. ... It wouldn't start so I replaced the spark plug, gas, and oil - then it did as yours. ... 1200 Watt Generator Won't start - Duration: 14:49.
gasoline engine on portable generator won't start what do I ...
answers.angieslist.com/gasoline-engine-portable-generator-won-start-I-d...
Apr 16, 2014 - gasoline engine on portable generator won't start what do I need to do ... PULL, Take OUT the spark Plug , make certain it is clean and DRY and then start allover again. ... start then when talking pulling rope use electric starter - if won't ...several times till starts, moving choke to OFF or RUN position once it ...
How To Fix A Portable Generator That Won't Start ' My ...
blog.mygenerator.com.au/how-to-fix-a-portable-generator/
Jan 21, 2016 | Electrical Supplies
What type of oil is use for dg6ln
If the unit you have is a four cycle engine " no oil/gw mixing required ..use any good SAE 30 oil...no multi grade needed...good luck...
Oct 05, 2014 | Eastern Tools And Equipment 1200 Watt...
After starting it it dies seconds later like it's out of gas
Check the oil viscosity and level, and also make sure the low oil pressure switch isn't the culprit
Nov 12, 2013 | Briggs Stratton Portable Generator 305cc...
Onan 5500 marqui gen set stumbles on demand
Steve,
The microwave alone shouldn't cause a problem for the generator as even the most powerful models run about 1200 watts or about 10 amps. An air conditioner on the other hand, can draw considerably more power to run depending on BTU size; 15 amps and up is not uncommon (and even twice as much as that though only briefly when starting).
If these were the only things connected and on, the generator should be able to handle them - again depending on the BTU size of the AC unit. Generators state their capacity in Watts, but must of the devices we connect are in Amps. Calculating Watts in an AC circuit is complicated, but pretty close to the much easier Watts in a DC circuit for most residential settings. Here's how it's done:
Watts = volts x amps. Pretty simple stuff. Your generator is rated at 5500 watts. The microwave is say, 120 volts / 10 amps - which equals 1200 watts. The generator has 4300 capacity available now. Suppose your air conditioner is rated at 120 volts / 15 amps - which equals 1800 watts. 4300watts - 1800watts = 2400watts capacity is left. But, the starting current for the AC is as much as 25 amps for a few seconds (and once started drops back to 15 amps) - which means there's only 1200 watts capacity left. Add up the rest of the appliances you're running at the same time (TV set, Cable / Satellite box, stereo, toaster, lights, computer, etc.- you get the idea), and you can see how you might have exceeded the 5500 watts capacity of the generator for a few seconds. It's at these times that your hear / see the generator speed falter and sputter, lights dim, etc.. If this is happening a lot, you may need a larger or additional generator.
I hope this helps and good luck!
Dec 25, 2011 | Watts Onan Portable Generator - 5000 ,...
What type of oil do i take for a porter cable 5250 watt electric generator?
Your generators take ordinary 10W30 motor oil.
We use these things on the job.
Don't turn engine upside down or on its side to drain oil, or oil will run into carburetor
Oct 24, 2010 | Porter Cable PorterCable BSI525W 5250 Watt...
May 17, 2010 | Coleman Powermate Proforce 6,000 Watt 12...
I HAVE A ETQ 1200 GENERATOR I NEED ON THE
The pdf for this generator is available at easterntools.com
Feb 07, 2010 | Eastern Tools And Equipment 1200 Watt...
Want schematic for gt 1200c petrol generator
Here is a link for the manual....printed on glossy paper, so difficult to scan.
http://rapidshare.com/files/285883408/GT-1200C_Manual.pdf.html
Good luck,
f.
Aug 19, 2009 | Eastern Tools And Equipment 1200 Watt...
Electrical Supplies Logo
89 people viewed this question
Top Electrical Supplies Experts
Marvin
Marvin
john h
Are you an Electrical Supply Expert? Answer questions, earn points and help others
