Question about Kenmore Dryers
Kenmore elite oasis dryer model 110.67032601 blower still works but heat stopped. took it apart and cleaned everything.now
Should I buy a heating element and also a dryer thermostat kit? all I have is a model number no part numbers to order by.
Posted by DeOnna Robinson on
Dryer not heating
Hello there and welcome to fixya
Here are the most common things that will need to be checked with a meter to ensure there is continuity on these parts no continuity means that the part is bad and needs replacement ok?
Thermal Fuse
If the dryer doesn't heat, but the drum turns, check the thermal fuse(s). The thermal fuse protects the dryer from overheating and helps to prevent fires. If the thermal fuse is blown, it will have to be replaced.
Enter your model number to see parts for your dryer.
Help me find my model number
Gas Valve Solenoid
The gas valve has two or more electric solenoids which open the valve to let the gas flow into the burner assembly. If the dryer doesn't heat one or more of the solenoids may be defective. If the igniter glows for 90 seconds but the burner flame doesn't light, replace these coils as a set.
Dryer Igniter
If the dryer doesn't heat, the igniter might be burned out. Check the igniter for continuity with an ohm meter. Dryer igniters burn out over time, similar to a light bulb.
Heating Element
The heating element on an electric dryer can burn out over time. If the dryer doesn't heat, the element should be checked for continuity. The heating element cannot be repaired and must be replaced if defective.
Heating Element Assembly
The heating element assembly on an electric dryer can burn out over time. If the dryer doesn't heat, the element assembly should be checked for continuity. The heating element assembly cannot be repaired and must be replaced if defective.
Flame Sensor
Gas dryers have a flame sensor to detect the heat given off by the flame. If the dryer doesn't heat, the flame sensor might be defective. Check the flame sensor for continuity. This is not as common as a burned out igniter or thermal fuse.
High Limit Thermostat
Although not common, if the dryer doesn't heat the high limit thermostat can be defective. It can be checked for continuity. If the thermostat is "open" the dryer doesn't heat.
Cycling Thermostat
The cycling thermostat regulates the temperature of the air in the dryer. If the dryer doesn't heat it may be caused by a defective cycling thermostat. This is not common.
Main Control Board
The main control board is normally not at fault when the dryer doesn't heat. Check all of the other components in this troubleshooting guide before replacing the main control board. The main control board cannot be tested easily and must be replaced if it is defective.
Timer
The timer is normally not at fault if the dryer doesn't heat. In many situations where timers are replaced they end up being returned. Check all of the more common components in this troubleshooting guide before replacing the timer
Oct 14, 2013 | Amana Dryers
Whirlpool electric dryer high thermostat replacement
test all this steps in according with your model, electric or gas. God bless you
Thermal Fuse
Gas Valve Solenoid
Dryer Igniter
Heating Element
Flame Sensor
Cycling Thermostat
Main Control Board
Timer
The timer is normally not at fault if the dryer doesn't heat. In many situations where timers are replaced they end up being returned. Check all of the more common components in this troubleshooting guide before replacing the timer.
Jul 21, 2013 | Dryers
The unit will run but no heat is generated. I am ...
unplug remove back and you can get to everything-mike
May 20, 2010 | Kenmore 63942 Dryer
Will not heat
If the model number you posted this question under is correct, your heating circuits are comprised of the following components:
1. Heating Element
2. Thermal Cut-Out
3. Hi-Limit Thermostat
4. Internal Bias Thermostat
5. Thermal Fuse
You can access them by UNPLUGGING the dryer and removing the rear panel.
As viewed from the rear of the dryer, your Heating Element will be located on the RIGHT hand side inside a heater box. The Thermal Cut-Out will be located on the outside of the heater box at the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals.
The Internal Bias Thermostat and Thermal Fuse are two small components mounted on the Blower Fan housing on the lower LEFT hand side.
You can refer to the following parts illustration for assistance:
http://pcappliancerepair.com/model-display.php
The components are listed as follows:
Heating Element (Item 17)
Thermal Cut-Out (Item 6) - This is a replacement kit. Includes Item 15 when ordering.
Hi-Limit Thermostat (Item 15)
Internal-Bias Thermostat (Item 20)
Thermal Fuse (Item 19)
If your dryer is NOT configured this way, please post back with your complete MODEL NUMBER (located on a nameplate around the door opening) and let me know.
If you need assistance on how to troubleshoot a dryer, you can refer to this link:
http://www.fixya.com/support/r3574266-thorough_dryer_advice
The MOST common causes of heat related problems:
1. Blown Thermal Cut-Out.
2. Missing 1/2 your input voltage at the wall receptacle (the dryer will still run with half the voltage missing, but won't heat - double check your source voltage at the receptacle and/or your circuit breakers.
3. Bad power cord, causing 1/2 the input voltage to be missing.
4. Blown heating element.
Read through all the information provided and let me know if you have any questions. I hope you find this information helpful.
NOTE: Take all resistance readings with the dryer UNPLUGGED and the component under test isolated (meaning disconnect any wire leads to ensure the accuracy of your readings).
Apr 23, 2010 | Whirlpool LER4634J Electric Dryer
Whirlpool dryer not heating up
1. Heating Element
2. Thermal Cut-Out
5. Thermal Fuse
You can access your heating circuits by UNPLUGGING the dryer and removing the rear panel.
Apr 22, 2010 | Whirlpool LER4634J Electric Dryer
My 80 series electric kenmore dyer runs but no heat
MY dryer has no heat
** UNPLUG a dryer before attempting ANY repairs. Lethal!
A dryer heater is controlled by the timer, a thermostat and a high-heat safety switch. The thermostat and safety switch are mounted on the housing around the heater.
Most likely - If the heater is blown, a visual inspection inside the heater housing will see a loose heater wire.
Next likely - Thermostat problems occur. I replace the thermostat and high-heat safety if either are suspect. Cheap, easy fix.9df7975.jpg
Least likely - Controller failure. This can be expensive ($80 - $400) so consider if you want to spend the money. A controller is actually fairly easy to change. Buy a new knob as you are likely to break it without experience and special tools.
Apr 17, 2010 | Kenmore 62602 Electric Dryer
I am needing to buy a heating element for my dryer (model # LER4634EQO) what # do I look for when buying element?
you use the model number inside the door,this is your part number,you can go to seras .com(parts)and order whatever you need-mike
Jan 29, 2010 | Dryers
The dryer turns on but no heat is this the heating element or something else?
Most likely it is the element. The only way to be sure is to visually inspect it.
Aug 20, 2009 | Kenmore Dryers
Heating element for kenmore dryer won't turn on
Hi, I have an 11yr old 80 series elec. dryer and just fixed the same problem. On the heater element is a thermostat with 2 wires and above that about 14" is another piece with 2 wires. I had to replace the top one. They sell them together in a kit called Thermal cut off kit. Sears sell it for 25.49 look up part number 279816 or 3399848 again these numbers are for my dryer but you can look them up on the sears parts web site. If you have a sears service center near by they let me buy the parts to see which one it was and then return the ones I didn't need. I hope this helps.Good luck
Jan 05, 2009 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
652 people viewed this question
Top Kenmore Dryers Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
