Question about Kwikset Locks & Locksmithing
I have a kwikset powerbolt2 49697/02 keyless entry installed and it allows me to change master code & put in another code but neither of them will lock or unlock it..gives me the flashing red & 3beeps
Posted by Michelle brown on
5 Related Answers
Anonymous
  • 38 Answers
SOURCE: kwikset powerbolt 1000 keyless entry deadbolt lock with keypad
Make sure that the bolt hole on the jamb side is recessed enough so the bolt gets a full extension. Without this externsion the bolt will not engage the key release. So when you do your quarter turn you are actually turning more. Remove the strike plate and drill the hole deeper until the bolt can extend all the way. Also double check your key to make sure it is not spurred or worn.
Posted on Sep 11, 2008
goalie39
Ed
  • 479 Answers
SOURCE: keyless entry code for 2003 lincoln aviator
Every car different, call an auto rescue or towing company, the trucks are usually equiped with slim jims, that can be used to gain access to your vehicle.
Hope this helps.
Ed
Posted on May 05, 2009
Anonymous
  • 365 Answers
SOURCE: Keyless Entry won't Lock/Unlock back door
Factory keyless?
Posted on Jun 14, 2009
Anonymous
SOURCE: how to reset kwikset pwerbolt 1000
6. Resetting the code: - please follow these instructions to reset the code on your Powerbolt 1000 unit:
  • Remove the inner cover plate from the lock.
  • Locate the small round program button near the left side of the circuit board (Red or Black).
  • To program, the latch should be extended out in the lock position, press the reset button once, then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. Re-enter the same 4-8 digit code to confirm, the latch should retract. This completes the programming. This signals that your code has been accepted.
  • To enter a second code, follow the same procedures as in step 3, but this time press the reset button twice then enter your code.
7. Replacing the batteries: - please follow these instructions to replace the batteries on your Powerbolt 1000 unit:
  • Remove inner cover plate located above the thumb turn on the inside of the door
  • Replace all 4 batteries with quality alkaline AA batteries. (Do not use rechargeable batteries.)
  • Ensure that the batteries are correctly oriented or unit will not function properly.
8. Changing the password code: - please follow these instructions:
  • Manually put the bolt in extended (lock) position. Press PROGRAM button once, enter new 4 - 8 digit code and then press LOCK.
  • Press PROGRAM button twice, enter the same new code and then press LOCK once.
  • Press PROGRAM button three times, enter the same new code and then press LOCK once.
    These stept will program only the new code you enter for your unit.
9. Why is my Powerbolt 1000 unit beeping? - To determine why your lock is beeping, please follow these steps:
  • Take out batteries and unplug powerstrip.
  • Let is sit for 1 minute then put the batteries back in and wait another minute.
  • If it does not beep, the keypad needs to be replaced (17733-1).
  • If the unit beeps, the powerboard needs to be replaced (A17734-4,3 Powerboard 1460 brass finish; A17734-4,26D Powerboard 1460 satin chrome finish; A17734-4,5 Powerboard 1460 antique brass finish; A17734-4,11P Powerboard 1460 bronze finish).
Posted on Dec 02, 2009
Anonymous
SOURCE: crimestopper keyless entry remote wont unlock or lock anymore changed battery still wont work
need to program a new remote to keyless entry system it is crimestoppper cs835 rke
Posted on Dec 16, 2009
I purchased a kwikset key pad maser lock and I can not change the master code to my code. Kiki set power bolt 2 touchpad keyless entry
First, I'm not a Kwikset representative.
* contact; http://ww1.kwickset.com/?subid1=7f921262-9a95-11e8-b8d0-66a96fabfdc3
*** Following is for information only.***
* Premis guide; https://www.kwikset.com/support/guides/premis-user/mastercode.html
* Smart code; https://www.youtube.com/watch?v=tl3wXtcutqg
* Factory reset; https://www.youtube.com/watch?v=T3FRuTUg8SQ
* Program Master Code; https://www.youtube.com/watch?v=1Grzxy0gSjM
* your best bet would be to remove lock set and take it down to your nearest Home Depot, Lowe's, City mill, Ace Hardware, etc. It's a pretty common lock brand. The store key maker, door hardware section should be able to help.
* I've found it's best to replace the lock set as these combo locks only last about a year in heavy traffic areas. Especially if it's exposed to weather.
* Constant opening and closing shakes things up real good. Lots of small wires and plastic parts break all the time.
* Key pads wear out fast. Especially if the code is not changed every month.
Aloha, ukeboy57
Aug 07, 2018 | Kwikset Locks & Locksmithing
How do I errase the code and reset a new code on my kwikset powerbolt keyless entry door look
Follow this link to find out how to remove the cover for your Powerbolt:
http://www.kwikset.com/Customer-Support/Product-FAQs/Faq/50160000000HhhEAAS.aspx
This link:
http://s7d5.scene7.com/is/content/BDHHI/40486-02
is the "manual" for the installation of the lock. Programming instructions are found on Page 6.
I'd recommend changing the 4 alkaline AA batteries at the same time.
Jul 05, 2011 | Kwikset Powerbolt/Electronic Deadbolt-...
Lost my operation manual and can't remember how to change the entry code. Linda
Here is a link to the installation manual for your lock:
http://s7d5.scene7.com/is/content/BDHHI/kwikset-smartcode
You will find the reprogramming steps here. I'd suggest replacing the 4 AA batteries at this time, if you haven't already done so.
May 21, 2011 | Kwikset 909 909-15 Satin Nickel Smart...
Was unable to get the '2 beeps' when attempting to set up keyless entry instructions. What do I do now?? Keys ok but no keyless entry possible,,,
Here's a link to the installation and programming for your lock:
SEE PAGE 9 (Troubleshooting tips) for your answer about the two beeps.
Here is a link to Customer Support:
http://www.kwikset.com/Customer-Support/Contact-Us.aspx
Mar 05, 2011 | Kwikset Locks & Locksmithing
We have the thumb press elongated handle on the outside of the front door entry. I was ready to enter the front door when I pressed the thumb handle and the whole set fell apart. Need instructions to put...
For the Lido Keyed Entry, go to this page:
http://www.kwikset.com/Products/Details/Door-Levers/740LL-26D-SMT.aspx
and click on "Installation Guide", found under the red text " Technical Documents"
If I've steered you to the wrong lockset, the product main page foe Kwikset can be found here:
http://www.kwikset.com/Products/Categories/Handlesets.aspx
Feb 13, 2011 | Kwikset 4 Lido Lh Passage Levers Satin...
I have a kwikset deadbolt model 898 keyless entry.i need to change pin number on keypad outside
I had the same question as my son installed the lock. Instructions should be printed on the cover you remove (inside the house). They need to make removing that cover MUCH easier, I'm always afraid I'll break it. Anyway, you press the button once for the first number. To enter a "guest" code, press the button twice then enter the 2nd code in the keypad and press the lock button. Now try both main # and guest #, both should open ttthe lock.
Feb 04, 2011 | Kwikset Powerbolt/Electronic Deadbolt-...
How do i change the entry code on my Kwikset 909 keyless lock? Just bought the house and want to made a code number of MY choosing. Thanks.
slide the cover off the interior of the door. you will see a program button. you can program two individual codes. to program the first code, press the program button once, then enter your code on the exterior keypad and press the lock button. for the second code you would press the program button twice, then enter the code and press the lock button.
Jan 23, 2011 | Kwikset 909 909-15 Satin Nickel Smart...
We have a kwikset keyless entry lock and need to reset it.
Try searching the type of kwikset lock from this page:
http://www.kwikset.com/Customer-Support/Product-FAQs/Search-Faq.aspx?prod=FAQ+Categories_Keyless+Entry
Jan 22, 2011 | Kwikset 909 909-15 Satin Nickel Smart...
How do i change the code in my kwikset 909 keyless entry
un screw the back cover located on the inside of the door , unscrew the two srewa inside that holds the front key pad , when it is removed you will find is has couled tags inside that are placed on regired key numbers for entry good luck
Nov 29, 2009 | Kwikset 909 909-15 Satin Nickel Smart...
Kwikset keyless entry is backwards
The config terminal is wrong. Take the cover off and move the 2 pin terminal over one pin.
Mar 03, 2009 | Kwikset 907 907-L03 Lifetime Polished...
Locks & Locksmithing Logo
295 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Charles Tidwell
ray gallant
STEVE SPAM REMOVER
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
