Singer Quantum Futura CE200 for thinner fabric the bobbin thread is not ingaging with the needle thread. Only works with thicker fabric.
SOURCE: while sewing on singer quantum
Mine did this and it seemed impossible to fix. My problem was a tiny bit of thread stuck in the bobbin cover (but it could be anywhere in the thread route). I ran dental floss through the path the thread follows and also in the bobbin cover and poof out came a small piece of thread that all my looking missed. Hope this helps.
SOURCE: the bobbin thread shows
This may or may not help, but perhaps you should check that your bobbin is wound correctly, and that you have it inserted into the bobbin case properly. I find that these are usually the 2 main reasons why the bobbin thread show through.
It could be the design, does it do it on all designs?
SOURCE: Bobbin thread
Not completely sure on your model but you have to adjust (loosen) the tension on the top thread to match the tension on the bottom thread. Usually there is a wheel on the upper right of the machine. the tension adjust is the knob inside that wheel. Turn counter clockwise about 1/8 turn. Then try and repeat until it works. Check owners manual for top thread tension adjustment if needed.
Good luck.
Please rate me.
SOURCE: Singer CE-200 Quantum Futura
i need the 2.5 upgrade software for my futura ce200 because i have windows 7 can i download it off the net??
SOURCE: Consew 230 continually breaks top thread at needle
What size thread are you using? With thicker fabrics, you should be using at least a size 50. Even a 30 would be better.
