Question about HP DeskJet Office Equipment & Supplies
I'm trying to set up my printer but I don't know the 25digit product code
The printer is hp deskjet f2400 all in one
Posted by Pat Ellison on
5 Related Answers
Anonymous
  • 52 Answers
SOURCE: HP Deskjet 3745 printer
start by downloading and installing the drivers for the printer
these are free from HP at
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=372335&lc=en&cc=us&dlc=en&submit.y=0&submit.x=0&lang=en&cc=us
Just select the operating system you are using, download, and click Run Hope this helps NGK
Posted on Sep 04, 2008
Anonymous
SOURCE: HP Deskjet 460 mobile printer
Pin code is 0000
Posted on Aug 29, 2008
Anonymous
SOURCE: need help installing hp deskjet f2400 all-in-one
just connect the printer , u r getting new hardware found ans searching the driver , u insert the driver cd in the cd drive and click ok
Posted on Jan 20, 2010
SOURCE: Hii need to reset the hp deskjet 680c printer.i
h10032.www1.hp.com/ctg/Manual/c00256077.pdf -
Above is your user manual.
Turn off your HP DeskJet printer. Turn it back on and connect it to your computer using the USB cable.
To reset the INK Counter, see below.
Click open the "Start" menu on your computer. Click on "Control Panel," and double-click "Printer and Faxes."
Locate the icon of your HP DeskJet Printer along with its model number. Right-click this icon and click on "Properties" from the pop-up list.
Click the "Services" tab and select "Service This Device."
Select the "Estimated Ink Level" tab. Click the option "Reset Ink Level." The printer will then show a refreshed ink cartridge level for your printer.
To reset all settings and print test page. see below.
* Press and hold the Power button.
* While holding the Power button, press and release the Resume button four (4) times.
* Release the Power button. A self-test page will print.
Posted on Jun 17, 2010
Azrael SRL
  • 11800 Answers
SOURCE: my hp deskjet f2400
What you hear is the sprocket on the motor that is skipping on the sprocket on the paper roll - the roll is out of alignment. You need to dismantle the printer and realign the roller.
Posted on Sep 04, 2010
I lost my hp deskjet f2400 series driver. i cant use my printer
Down load a new set of drivers directly from HP.
Please dont forget to vote if you liked my answer
thanks
Feb 10, 2011 | Office Equipment & Supplies
I need to know if I can send a fax with my HP deskjet F2400 all-in-one series printer-scanner please...
The HP Deskjet F2400 model printers are All-in-One which will let you Scan/Copy and Print but they do not have the Fax feature.
Oct 09, 2010 | HP DeskJet F380 All-In-One Printer
Installation
you could try going to : http://h20000.www2.hp.com/bizsupport/TechSupport/SupportTaskIndex.jsp?lang=en&cc=us&taskId=115&prodTypeId=18972&prodSeriesId=3811093
Under the "Drivers and Software installation" heading select your Operating system, then download the required file. (its basically what is on the CD).
Note HP are well knows for have a slow website so you might want to find a good book or watch some tv while it downloads.
Jun 08, 2010 | HP DeskJet F380 All-In-One Printer
I can´t install driver for my printer HP Deskjet F2400 on windows 7
I believe this site may have the drivers you need for Windows 7:
HP Technical Support for F2400 series Printers
Simply select your specific model, and look for the Software & Driver Downloads link. You should only need the Basic driver to get your printer working. The full featured driver includes HP software and utilities designed to work with other product features.
Some drivers are packaged as 32 or 64-bit. To find out which architecture of Windows you're using, check out this page: http://support.microsoft.com/kb/827218. Note that the instructions for Vista are the same for 7.
Remember to rate my solutions! If you have time, drop a testimonial too - they really make my day. :)
Mar 29, 2010 | Office Equipment & Supplies
I need to know how to replace the ink cartridge in a Deskjet F2400. The ink is out and it needs to be replaced.
Hi
This will tell you how to do all.
I have put a PDF files on my website for you to download.
Just click on the links it will download for you.
It got all you need to know in this file.
You can read it on site and print it strait off the website or save it to your PC then print it out.
Click LINK= http://www.4all2sell.com/pdf/HP-DeskJet-F380-Manual.pdf
You will need a adobe reader to see this file If you not got an Pdf reader you can download it off this link free.
http://www.adobe.com/products/reader/
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 11, 2010 | HP DeskJet F380 All-In-One Printer
Need help installing hp deskjet f2400 all-in-one printer
Jan 20, 2010 | HP DeskJet F380 All-In-One Printer
Hey deskjet f2400 printer wont print, says it is "offline" when i put it online it says "there is an error with the print system" ... driving me nuts
I have the same problem. Used 3 times and now it just won't print it says that it is "offine"... I don't even know how to put it online!! Please help
Nov 23, 2009 | HP DeskJet 3930 InkJet Printer
46 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
